First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
islandan
Perfect !
Thanks Duff  ;)
Quote from: duff on December 09, 2007, 07:21:09 PM
@all
Here is an single html document of Thomas's Posts  plus a seperate set of documents containing 119 posts  to the TPP-Project..
-Duff
Pegasus
Hi Walter.
Thomas expressed openly his worry about people that dont wanted to show their result on his devices in general,and decided to discuss this problem with the moderators.It happened when we was talking with the V6,not the V12.The two replicas I was talking about was the V6.
Even if you say "i will show my results",these are only words ,and Thomas  wanted  the certainity.
Certainly was for that reasons that he said on his website that he wanted that the "rigth" people gets the full plans.
The rigth people are the ones that gives support to his project,not the ones that disappears,saying" Thank You;Bye..."
Essentially Thomas was not sharing his findings.Hes idea was:" I need your help and in exchange,I give you the plans."
regards,
Cyrano.
neptune
We do not know if or when Thomas will return,So all we can do is work with what we have. We have heard nothing from Hurricane, who claimed a working replication. Untill we do we have no proof of hi s existence. We are fairly sure, that tinu has built a v6 and that he cannot get it to work. We do not know how close this is to the original spec. Indeed, there are grey areas in the spec.
! we cannot be certain exactly what graphite material to use. { the diameter seems critical, as Thomas describes the dirty job of turning these iv a lathe]
2 We are not sure of the capacitors[ air spaced or other dielectric] or what the capacitance should be. for eample. capacitance of main cap depends on how tightly it is clamped together.
3There may be other variables, such as the sand[or you tell me]
4Does it need to be on the ground floor? touching the soil? What is the effect of having a lon g earth cable?
         Thomas said that if operated without a load, the voltage would go very high, and the effect would then dissapear. Owing to the  very high internal resistance of the device,i suspect High voltages would always be present within the device [Thomas speaks of shocks and static problems with larger models.] Therefor, it would need a dry atmosphere to work.These are my thoughts today. Can you add to them<
duff
In Thomas's defense:
If you had you & your family's life threatened how would your react?
Your initial reactions might be you guy can't stop me,  but once you've had time to think about it and everything sinks in it may bring a different response.
-Duff
vipond50
Hello Duff
I do not understand your Q What do u mean??
Have any of u had a problem accessing the Overunity site???
Made it this time, but fought like hell 10 minutes ago
Keep getting this message
"User 'hartiberlin1' has exceeded the 'max_questions' resource (current
value: 100000)"
What does this mean ?
Thanks Bill
