First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
neptune
Just had a hour working on my V6 capacitor.Its very cold in my garage...Re Skywatchers comments on the Pegasus experiment. I agree that the use of a "controll cup" outside the pyramid is vital. It would be nice if someone with a 1 metre gypsum covered pyramid could duplicate this. Cant do it myself yet as I am still waiting for my welder man. This could turn out to be the nearest we have to proof at this stage. I suggest also that the experiment also be tried with a SMALL amount of salt water as well. Someone suggested that the part played by the sand is that of a piezzo generator. There is also corroboration of this theory in TT`s words, where he emphasises that the lower ends of the graphite rods must hang free and not be restrained in any way. Two days ago I felt really low, but today I am much more optimistic. Hang in there brothers...
pese
Quote from: Pegasus on December 11, 2007, 01:29:39 PM
@Skywatcher
All that you are saying was made.I have a scientific background.I posted the result to see if I'm becoming crazy or not,(to see if someone else is able to reply the experiment...).No,I havent the gypsyum plates mounted,because I used a different pyramid made of aluminium pipes.and with little dimensions...
TT say?d
Aluminium WILL NOT WORK
Pese
JosefH
@ pese,
i often have heard from  russian pyramids  they ara built in acryl.
and in combination copper, al and acryl why not?
Josef H
tao
Quote from: pese on December 11, 2007, 02:56:38 PM
@Skywatcher
TT say?d
Pese
This is correct. TT said that about aluminum because of his specific construction and how he grounds the output cap to the frame of the pyramid, in which case TT found that steel worked best/better...
It is the SHAPE that really matters, the russians, and others using even wood for the frame, have all noted the various 'pyramidal effects', so it is the shape that ultimately matters. Therefore, Pegasus's aluminum pyramid CAN easily show true pyramidal energy effects. In such case, by Pegasus doing those tests, we can better learn how TT's circuit works within his pyramid.
skywatcher
TT say?d
Maybe it won't work for generating electricity, but for other things.   ???
Yesterday i browsed through the older pages of this thread, and found the following statement which was made by TT two years ago:
Quote3.) Der Pyramidenrahmen beteht aus einfachem Stahl (St38) welcher geschweisst und lackiert ist. Ich kann best?tigen, dass das Material des Pyramidenaufbaues bei der Funktion ?berhaupt keine Rolle spielt.
Der Rahmen sollte nur stabil sein, sonst nichts.
Translation:
3.) The frame of the pyramid consists of simple steel (St38) which has been welded and painted. I can confirm, that the material of the pyramid plays absolute no role regarding the function.
The frame only should be stable, nothing else.
This is one of TT's contradicting statements. To say this he should have tried other materials, and have seen that they also work.
I also found another statement where he stated that he had tried other materials (copper, aluminium, even wood), and only wood didn't work at all, but copper worked, but with reduced performance.
