First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
0 Members and 23 Guests are viewing this topic.
Walter Hofmann
Hi all
to the sand I use the sand from old fashion main fuses this is pur silica. in germany the old schraubsicherungen if they still can be found.
greetings
walt
magpower
Just putting the plumbing together with rods and should the ends touch the sand or not. To me it makes sense so both rods touch sand and make a circuit, and adding the salt water conducts the sand with rods. Having it open at end I really don't know how this would work. Anybody know for sure ?
Thks
Wayne ???
Walter Hofmann
Hi all,
I just tested the pure copper frame with the graphite rods and the bottom filled with saltwater solution. by connecting the neg to outside of copper pipe and pos. to each of the graphite rods the result was 0.456V  and 0.461V. after inserting the frame in to the pyramid frame ( no cover jet) and standing inside my metall workshop on top of a table saw with cardboard connecting the neg to the pyramide frame and the positive to ether of the rods the voltage did fluctuate from 0.231V to 0.482V but only at DC setting nothing at AC setting. I also did see a increase of voltage by turning the frame out of the center north line to NNE about 5 degree. this actually confirme's that the magnetic northpool is about 5 degree West of the geographic northpool, maybe this is also the reason what TT talked a while back and in his video that there was a change by turning the pyramide a bit out of direct north but he did turn the whole pyramide. I try this too but it did not bring the same result.
this was a realy neat experiement
greetings
walt
duff
Quote from: duff on December 11, 2007, 11:28:59 AM
@ guys in US
I have had my frame spot welded for a while and have been struggling with the issue of the 3/8" pipe.
I was unable to find 3/8" pipe at a reasonable cost (they wanted $100 for 20' length) and had substituted 3/8 rod instead. Now I think I need to look for  pipe again before I weld this thing up...
Where did you guys locate your 3/8" pipe.
-Duff
@ guys in US
Ok - I've found black steel pipe in the US
Lowes has it.
What your looking for is black steel pipe NIPPLE and it is less than $3.00
-Duff
Edit: I forgot. This will provide you with a short piece only. I guess you could couple them together for the full length from the base to apex. They are threaded.
skywatcher
Quote from: Walter Hofmann on December 11, 2007, 04:36:28 PM
Sounds not bad.  ;)
How much is the voltage difference between maximum and minimum voltage when you turn the pyramid through a range of 90 deg. ?
