First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
magpower
Quote from: Walter Hofmann on December 11, 2007, 04:36:28 PM
Hi all,
I just tested the pure copper frame with the graphite rods and the bottom filled with saltwater solution. by connecting the neg to outside of copper pipe and pos. to each of the graphite rods the result was 0.456V  and 0.461V. after inserting the frame in to the pyramid frame ( no cover jet) and standing inside my metall workshop on top of a table saw with cardboard connecting the neg to the pyramide frame and the positive to ether of the rods the voltage did fluctuate from 0.231V to 0.482V but only at DC setting nothing at AC setting. I also did see a increase of voltage by turning the frame out of the center north line to NNE about 5 degree. this actually confirme's that the magnetic northpool is about 5 degree West of the geographic northpool, maybe this is also the reason what TT talked a while back and in his video that there was a change by turning the pyramide a bit out of direct north but he did turn the whole pyramide. I try this too but it did not bring the same result.
this was a realy neat experiement
greetings
walt
Thats good news Walt and my question did you ground the frame to earth ground, this is very important. I will try the same test tonight as mine is covered and ready to go.
Wayne
Walter Hofmann
if I turn the pyramide out of north at abot 30 degree the voltage goes down to 0.0752 to 0.056V
greetings
walt
Quote from: skywatcher on December 11, 2007, 04:49:14 PM
Sounds not bad.  ;)
How much is the voltage difference between maximum and minimum voltage when you turn the pyramid through a range of 90 deg. ?
MT
By coincidence I visited IKEA today and they also sell sands in various colors in flowers department. Colored sands probably not good idea but they have also light grey one that seems not colored. On the sack Made in Egypt funny isn't it? Did not try it yet just bought it to have some options in my pyramide.
Quartzsand is also used in glass industry i'll try to get some of it from a glass factory.
MT
Walter Hofmann
No I did not ground anythings thats why I had the cardboard between the table ( iron) and the pyramide frame.I did wana find out if the ground to earth is so importand.
I have to find a way to get the pyramide outside my workshop because my big door is blocked and the walk door is only 32 inches where the pyramide does not fit I probably need to install a 36 inch door
greetings
walt
Quote from: magpower on December 11, 2007, 04:50:34 PM
Hi all,
greetings
walt
Wayne
magpower
Walt
You could just run a single wire from frame to your house plug ground, as all panels have earth ground, just a thought!
