First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
helmut
Quote from: magpower on December 11, 2007, 04:59:15 PM
Walt
You could just run a single wire from frame to your house plug ground, as all panels have earth ground, just a thought!
Hi Walt
I remember,that Thomas said,that without Ground,it will not work.
About the Sand: Perhaps Sand for Aquarium is of use.
Good luck
helmut
Walter Hofmann
thanks helmut,
I did wana find out if you actually realy need the ground and it seems to me that it whould also work without how far I dont know but if it works without whould mean any connection with other reason like "earthbattery, or galvanic cell or influence from main power will be eliminated. just wana say I dont have connected any coil and capacitor that will come after I checked out the groundconnection influence.
I wil;l try the ground connection tomorrow
greetings
walt
Quote from: helmut on December 11, 2007, 05:41:31 PM
Walt
Hi Walt
Good luck
helmut
IndianaBoys
If you have a PetCo in your area, they have a very fine quartz desert sand that they sell in 5 and 10 pound bags.
They use it in their reptile cages:
http://www.petco.com/product/4957/Zoo-Med-Repti-Sand.aspx
Best regards,
IndianaBoys
tao
Quote from: IndianaBoys on December 11, 2007, 06:45:14 PM
Best regards,
IndianaBoys
Look what I just bought! LOL...
5 lbs for $10... PURE quartz sand, no additives, and very fine...
Thanks for the heads up IndianaBoys.
Walter Hofmann
Hi neptun,
wher you got the info that the whole top of the frame is full of sand to? I could not find it anywhere and if you look closely there are the wire connector where the wire are connected to the rod below the top ( dots)
greetings
walt
Quote from: neptune on December 10, 2007, 06:27:05 AM
message to Walter Hoffman. There is no need to shorten graphite rods. Diagram shows that rods extend inside T pieces [T stuck] at top corners of frame. The whole of the top of the frame is full of sand. Hope this helps. Neptune
