First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
neptune
Magpower, do not inject salt water at the top. Inject it slowly into the lower drainhole, and stop when it comes out of the other hole.
magpower
Thanks Neptune
Never saw this anywhere, will do this, so the rods in sand are dry I guess. Will do volt test and see.
Thks
Walter Hofmann
Hi all
do not fill saltsolution from the top to fill you need to use the two holes on the bottom fill in the bit higher one and watch wenn it comes out on the lower one. the upper portion with the graphite rods should be dry.
greetings
walt
Quote from: magpower on December 12, 2007, 03:19:43 PM
Quote from: Walter Hofmann on December 12, 2007, 05:45:09 AM
Hi all,
here are a tip if you put the graphite rod in to fill it be very carefull and hold it in the right hight and location because after the fill the rod can not be corrected or it will break I had this two times and shake the pipe a bit because if the sand is not realy packed it will compact on the bottom by filling with the salt solution and there will be a gap to the vertical portion where the rods are. oh and close the holes or the sand will run out there had this too.
greetings
walt
Walt
Thanks for the tip as last night was wondering what to do, Just to confirm the total U shape is full of sand, then we inject the water/salt solution from top, until we see some sign of it coming out 2mm below the rods, Right?
I took some pics but forgot camera cable so will post soon.
Also I got .4v to .5v levels in D.C. Using A.C did not read nothing. Just rod in beaker with salt solution and meter to ground, the started tried a 9000mfd/ large cap and tried to charge it, could only get to .5volts. With a small 100mfd could not get this. It was very odd how the meter would jump up and down with readings. I did earth ground mine last night so more test tonight with U tube and 2 rods this time.
Walter Hofmann
Hi neptun from frosty england we have 28 degree C here,
my tablesaw has plastic caster is also insulated from the floor and between the cast isorn table and the pyramid frame is thick cardboard another insulation.
I had another expierience I did wana try to adjust one of the rods to fixate it and brook it but I did not realiese it right a way and then I took measurements  and I can tell you the rod was broken about 40 mm from the top and had no connection to the other part of the rod and the DVM still showed the fluctuating Voltage of 0.23 to 0.45V. but the other side rod was perfeckt. I also used a analog Voltmeter to find out if the DVM shows the right value and it did show the same even if it is hard to read with this jumping of the needle
OK maybe somebody ca try something of this and confirme or not
greetings
walt
Quote from: neptune on December 12, 2007, 06:40:21 AM
We now seem to have conflicting info as to just how much sand to put in . I guess it is a case of "try it and see". Walter, here is a small but significant experiment to try. I f your table saw is not fixed to the floor, put some cardboard under it, and put the copper fame inside the frame of the table saw, if it has a metal frame. so now you are using a square[cuboid?] frame instead of a pyramid   . Is the voltage still there? Please let us know. Greetings from Neptune in Frosty England.
Walter Hofmann
Hi all again,
I forgot to mentioning that all my above results are just with the frame of the pyramide I have not coverd it what I will do tomorrow after fixing the mishap with the rod.
greeitngs
walt
