First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Walter Hofmann
Quote from: MT on December 13, 2007, 03:06:42 AM
Quote from: Walter Hofmann on December 12, 2007, 05:10:55 PM
Hi neptun from frosty england we have 28 degree C here,
my tablesaw has plastic caster is also insulated from the floor and between the cast isorn table and the pyramid frame is thick cardboard another insulation.
I had another expierience I did wana try to adjust one of the rods to fixate it and brook it but I did not realiese it right a way and then I took measurements  and I can tell you the rod was broken about 40 mm from the top and had no connection to the other part of the rod and the DVM still showed the fluctuating Voltage of 0.23 to 0.45V. but the other side rod was perfeckt. I also used a analog Voltmeter to find out if the DVM shows the right value and it did show the same even if it is hard to read with this jumping of the needle
OK maybe somebody ca try something of this and confirme or not
greetings
walt
Hi
very interesting what you see together with magpower. I'll certainly try it just dont have pyramide yet, still buidling it (doing base with screws need it flexible), problem is time I'm traveling this weekend and will all preparations I cant finished it now. I estimate to get back to building next tuesday  :(
Anyway this could be proof of principle. So you get this fluctuating voltage and if you take that copper frame out of pyramide then voltage effect stops?
Having pyramide I would try to just cut short piece of copper tube close it on one side put sand + salt water and rod. then measure voltage from rod to pyramide frame and try different positions of it within and outside. I would also make photos or better video. But thats what I would do maybe you have better ideas.
If you can please dont go silent I dont know what to expect from internet anymore.
have a nice day,
MT
Hi MT
dont worry I dont go silence on this. But like TT says the graphite rods should not get wet I dont know why but this is what he said.
greetings
walt
magpower
Quote from: Gustav22 on December 13, 2007, 03:31:44 AM
I have also build a pyramid and a V6 converter.
Unfortunately I can not yet observe a voltage rise when I place the converter in the pyramid.
I connected each graphite rod to the upper end of a coil and then I connected the lower end of each coil to opposite face-plates of the capacitor.
So my converter basically consists of three electrical  units. These are:
- short graphite rod + coil A + capacitor plate A
- long graphite rod + coil B + capacitor plate B
- tubular U-frame
After adding the salt water I read the following values (regardless whether the converter is inside or outside the pyramid):
- capacitor plate A to capacitor plate B: 0.01 V
- capacitor plate (A or B) to tubular U-frame: 0.1 V
The U-frame is always negative. I find this remarkable. Does anyone have similar values?
- capacitor plate A to apacitor plate B: 70 kOhm
- short graphite rod to tubular U-frame: 10 kOhm
- long graphite rod to tubular U-frame: 2 kOhm
I don't know:
- which part of the converter should be grounded (i.e. be attached to the grounded pyramid frame) ?
- which part of the converter should be floating (i.e. be neither connected to ground nor to the load) ?
- which side of the pyramid can best be left open during testing (N, S, E, W) ?
- should the converter be mounted so that the plates of the capacitor face N and S or should they face E and W ?
Tried to upload pics not yet, this site is getting very hard to talk to lately. Just a thought maybe more to a yahoo group. Got my pickup tubes done with rods and desert sand I used from pet store. Next plates.
Did you use 10 plates to make a capacitor, and this faces the same North - south. This plate or plates I think should be the focal point of your pyramid. I think if it is working right open circuit reading should be very high and with 8 ohm load brings it down to 6 volts or so. I will try once more to post and try pics later.
neptune
test message from neptune, having difficulty accessing this site
neptune
Gustav22, do not give up, try the tests Walter describes. Walter, I think you misunderstood what I said about the table saw. what i meant was, hang the converter inside the metal frame of the table saw instead of inside the pyramid. This will test if the effect is due to the shape of the pyramid.Gustav, the orientation of the converter is capacitor central. one side of copper frame east and one side west. I believe wires lead out to the north, and if this is the case, TT has the north face as the door. See pictures on page one of this topic.
    My base board comes tomorrow, welding saturday. Gustave, post yor full specification. Origin and diameter of graphite rods, diameter of copper tube, type of sand, is pyramid frame grounded. More info you send, more help you will get. If we find what dont work, we are nearer to finding what does.
atlantex
Hi all,
Thomas is back with great news!!!
http://trawoeger-pyramide.info/
there is also a new yahoo group for the TTP project.
http://groups.yahoo.com/group/pyramide-project
cheers
atlantex
