First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
tak22
@Tigrotto
>:( Please stop antagonizing Thomas on his own website!  >:(
He said he'd have V12 specs for us in a few days, so please at least wait until they arrive before pushing his buttons about V6, costs, etc.
There's a lot of us out here trying to be courteous, please don't mess up our opportunity!
tak
Walter Hofmann
Hi cyrano,
something must be wrong at your setup because if I put wetsand ( what should not be in the pyramide setup) then you should see at least 0.4V measured graphite rod to copper tube because that works as galvanic cell. I also got 0.4 to 0.5V with dry sand and the electrode against the copper tube.
greetings
walt
Quote from: Pegasus on December 14, 2007, 12:59:54 PM
Hello people...
Anyone here has tryed to put the wet sandquartz into the center of the pyramid?.I have repeated the experiment...and it works again.
I'm trying to get a digital multimeter to get precise measurements,because my analog one dont show the detailed numbers.Actually  with wet sand and graphite electrodes, not exposed to the pyramid,dont show voltage reading on the instrument.If I do the same measurements with the wet sand exposed with the center of the pyramid,I got voltage reading.The voltage augments if I remove the graphite electrodes,and immerse the probes directly in the wet sand!.I want to get some pics of this stuff to show here.I used a little old  pyramid made of aluminium pipes.The sand was wetted with tapwater (it is conductive...) Time exposition 24 hours.
The "battery" gets very fast polarization but seems to recharge leaving it alone for some minutes.What happening?.I dont expected tys type of result with aluminium;it was just for a simple experiment......
Coming soon....
Regards,
Cyrano.
neptune
Hi Walt. I think that Cyrano is measuring the voltage between 2 graphite rods in a vessel of sand,and I am not sure that copper is mentioned, or involved. If this is correct, this is a different ball game, and as I understand it a galvanic cell needs 2 differerent substances to act as electrodes. so if the experiment of Cyrano[pegassus] is repeatable, with voltage inside pyramid but not outside, then, without doubt, we have actual proof of something weird and measurable happening inside the pyramid.
Schpankme
I've been following this thread very closely and it's very impressive to read that ALL of you are getting 25% the power-out, one gets by sticking a copper pipe into the earth.  Maybe you just need to increase the size of your Pyramid's by four x4.
- Schpankme
