First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Pegasus
@Walter,
I made my experiment simply putting some quartz sand in a glass cup,and exposing it to the "energy"of.the center of the pyramid.The pyramid used is made by aluminium pipes,it is in scale with the great pyramid of Giza,and has no walls,just the skeleton of the shape.Also it is little;its heigth is less 20 centimeters.
After 24 hours I take the  vessel out of the pyramid,and I add some tapwater to just wet the sand.I add the two electrodes of graphite(with different length) and I measure voltage.I take the measurements outside the pyramid,not inside.There is no copper in the vessel,only two graphite rods,quartzsand,and some tapwater;its clear?.If I remove the electrodes and I insert the probes of the voltmeter,DIRECTLY in the wet sand exposed to the pyramid,I got voltage.This phenomenon  resemble piezoelectricty,but I'm not sure,because I havent take measurements with the same sand -not- wetted.In these experiments .If I use sand not exposed to the energy of the pyramid,I get pratically NOTHING,no voltage, in every mentioned cases.
I have to add that the "battery" created, get fast polarization,but if I leave it undisturbed for some minutes,the voltage returns to its original level.I noticed that after the exposition,I can take positive measurements from the wet quartz,for about two days,and then the phenomenon stops.The voltage I got is less 2 Volts.I will send some pics of my experiments,and if I have time I will send also the wav of the possible vibration coming from the quartz exposed to the pyramid energy.I will get it conecting the voltage of the quartz to some amplifier.
Now I ask to people that have the possibility to repeat the experiment into their pyramids,made of aluminium or not,to see if they get some results.It is higly appreciated that some people with academic knowledge will give me an explanation of the phenomenon.If it is piezoelectricity,were is the source of the mechanical excitation of the quartz?My voice,the noise around me?NO, because I tried the same experiments with the sand NOT exposed to the energy of the pyramid,and it -doesnt- work.
I HOPE IT IS CLEAR NOW.
Regards,
Cyrano
jrader
this may be of interest i dont know,i took a flat carpenters pencil,and a roofing nail,mixed a solution of white vinegar and regular bleach,put them in the solution ,got over 2 volts,then i burnt the copper off a penny to get to the zink,zink as neg , carpenters pencil as pos ,in the solution of reg.bleach,mixed with white vinegar got better than a volt and half,oh i added salt to the solut also. got voltage in just plain water also but not as much.kept the probs on for a while,volts slowly rised,well thats about it .
        jrader
neptune
Hi jrader. I find your experiments very interesting. what you have created is a cell. whilst these cells are useful, they have the snag that the chemicals get used up. This is not quite the effect we seek with the pramid. we are looking for everlasting free energy. Ten out of ten for effort!
jrader
a cell true,but also ac voltage accured, isent sand ,
salt water carbon copper a cell lol ty.
            jrader
duff
@Thomas
In the description that you are rewriting would you please tell us the following:
Are the dimensions of the energy pickup unit critical?
How much tolerance is allowed on the dimensions?
-Duff
