First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Walter Hofmann
Tigrotto
This message is for the person saying here he replicated unsuccesfull the experiment. please replay, otherwise all of us will waste the time here.
In order to help you, let us know plainly ALL the detalis you followed up when building your failed experiment.ALL: starting from pyramid construction finishing to electric connection! All
Thanks,
Tigrotto
Koen1
Tigrotto, why do you focus so much on a failed replication message? If mrgalleria does not want to give details on what exactly he did, then let him.
From the little that he did post, I assume he has not actually replicated the entire device.
After all, he says he built a pyramid from copper tubing... ?! Where did he get the idea you need a pyramid made of copper tubing? The pyramid in the video does not at all look like copper tubing. And the text documents do not mention a copper tubing pyramid frame either.
The video and any documents all clearly show that one needs to build a pyramid with metal sides. Not a copper tube frame! A full pyramid, made of metal!
Only the "convertor" in the center is made partially of copper tubing.
So instead of trying to pry information from a person who first of all said his "replication" did not work and second appears to imply he has not even built the actual pyramid properly (which makes it into a haphazard attempt rather than a true replication), perhaps we should focus more on the information we can attempt to get from people who have actually build a pyramid, or perhaps on reverse engineering the "convertor" from the video images and documents?
The pyramid itself is simple. It is the "convertor" we need to figure out. I think ;)
On another note, the pyramid frame shape in itself is already quite interesting...
If properly built, a pyramid frame can be made so that there are 4 axis perpendicular to eachother. Obviously this allows for two opposing axis to be fed signals exactly 180 degrees out of phase, which could result in interesting effects over the other 2 axis... If we can believe anything of the philadelphia experiment and related "montauk" projects, a setup like this was used to alter local space-time (with some additions to the setup of course).
Also, there is a little interesting documentation on a wire-frame based electromagnetic pyramid device referred to as a "telepathic pyramid" which appears to suggest a direct link between the pyramid frame 'antenna' and scalar wave technology, and in related texts a pramid shaped power source is mentioned. Okay, this specific information relates to accounts of ufo contactees so it is quite "out there", but the pyramid device design is very interesting. ;)
pese
 i have traslated this for tigrotto german to english.
an because i have plaed this again and again , i understand
that this is kaked power.
this people have not found this , that traw?ger found.
give attention to video , to the meter , to nois of moter (shown the meter!!)
some switches was "clicking" extern .  (possibly also noise from an extern motor . nothing is correct , not to see the  cbles.
end of video , the person say : Now i swich off !!
from powersupply ???
Interesting.
Mister Nagel . live in my Home-City.
I tried to visite hime (no phonenumber) , so he is not open the dood,
even when he is in home.
I dont belive this video say more than an stupid fraud.
that was traw?ger have find was the correct way
even , when this video was made in Nagel?s home , than the pyramide
was not placed "exactly" to te earth magnet field in the right angel degree.
Pese
pese.cjb.net
Koen1
Quote from: pese on November 08, 2007, 04:38:40 PM
Interesting.
Or the video camera maybe? ;)
QuoteMister Nagel . live in my Home-City.
Ok, and which way is that then ?
It is not what we see in  the video, with the metal pyramid and the copper tube convertor in its center?
which means what, exactly?
Asfar as I can figure, it's not about it being perpendicular to the earth magnetic field anyway, so why would that matter?
