First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Pegasus
@Gustav.
Yes the longer rod have always the positive potential on the multimeter.Only one time it changed,but I think that was a measurement error.
Regards,
Cyrano
neptune
I am a bit frustrated because I am still waiting for welder man. So all I have today is a collection of parts. I find it strange that the length of the rods determines polarity. Perhaps there is an ideal RATIO in the rod lengths, and this may possibly effect the voltage.
@pegasus. You say the rods are not orientated. Experimentation may show that it works better if they are. My guess is that it might work better with thick rods[lower internal resistance of the device] All these things and more I will be trying soon. Another vital thing needs to be tried here. We are told. Voltage inside pyramid and no voltage out side. Big question. What happens inside a metal frame that is NOT pyramid shape? { cube, cuboid, other]  No need to build a square frame, improvise, use a metal bench frame etc. or even inside microwave oven[not switched on!] Please post all results, pos or neg. A few days now I will be doing my own experiments.
Tigrotto
@Pegasus,
thanks, very accurate in answers. But ar estill missing these:
1. You said you got continuously these 2Volts : for 24 hours if I'm not wrong? When the setup was still under pyramid?
2. You didn't replay to these question: What actually was the resistance between the two metallic electrods? InOhms.
Example : Supposing you'll have 2ohms as resistance and 2V as voltage. That means that you could obtain ideally about 2Watts! not bad at all !
3. Another strange fact you didn't mention sufficiently: You said : the longer graphite rod was the (+).
OK, but what about the two metallic electrodes when penetrating sand? Which of them are (+), which are (-)???
4. Now the last one strange experiment I suggest you: when the setup is under pyramid, measure the voltage from one of the two graphite rods and Ground!
Waiting for your replay, I remain.
The next step will be the energy concentration!
tigrotto
Pegasus
@Tigrotto
The phenomenon continues for about 24 hours OUTSIDE THE PYRAMID.
I got my voltage outside the pyramid,this is the very strange fact,that let me to suppose that the pyramid focus some form of radiant energy on the quartzsand.
R.E, is similar to radioactivity.I suggest to you to study this topic if you want to understand what I mean.
I will post all the measurements when I will receive my new multimeter,and please dont insist anymore.I have to focus myself on the finishing of my T.T. pyramid,and I suggest to you to do the same,because  Thomas has homitted NOTHING from his explanations and he give already all the specs to replicate the free energy.You have only to do it properly..I'm not here to reinvent the V6,but only to advert people tha something strange is happening in the pyramid with the quartz:i have said that I will post the pics and the waw of the vibration.What do you want more? A video?..Qien sabe? .
Regards,
Cyrano
Tigrotto
@Pegasus,
What i'll say in the following are not critics, but only science, basic, not advanced science!
24 hours 2V means absolutely nothing if you don't measure also the electrical resistance !!!
24 hours on what resistance??? Resistance = infinite means power nothing!!!!!
Are you so kind as to measure the electrical resistance ? 2V measured continuously with a voltmeter means A LITTLE BIT MORE THAN NOTHING!!!  Why? Because the resistance of the voltmeter is about infinite so that the power you "think" you got is about ZERO Watt!!!!
Should you connect your electrodes on a finite resistor example :2 ohms, then try to measure for how long you'll get these2Volts!!!!!!
If you think I said here stupid things, you're wrong. There are guys here understanding some more about simple electric circuits ! these are basics!!!
I'm a non-skeptic scientist and some guys here know this!
If you ignore my above words, you're wrong! Measuring power means a finite resistance and a finite voltage across it , and a certain duration of this experiment!
2. What I suggest you is this : after 24 hours in pyramid, put a 2 ohm resistance across your battery and measure the voltage ( again, only under pyramid) . how long will last this 2V ???
This is the UNIQUE WAY TO DECLARE YOU GOT POWER!!!!!!
3. How could you be so sure V6 documentation is complete? ONLY if you followed religiously Thomas indications you could say so! Did you do that???? Otherways, bla, bla bla,...
Sincerely ,
Tigrotto
