First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
bobinaccounting
I think this is basically a sail, Wouldnt the coil part need to be underneath the pyramid to properly work? where is the center of gravity would be?
neptune
Pyramid frame completed today.I have used angle-iron throughout-30x30x5mm. TT says that the vital dimensions are those of the inside surface of the plasterboard skin, and I have stuck to that as closely as possible. Hopefully buying gypsum board tomorrow. One thing that keeps coming back to me is TTs words about building a larger pyramid, and about having problems with static electricity. Could staticHope to complete the job by Sunday, work permitting. be an important part of the whole thing? My basic plan is to complete my duplication, and if it does not work , I have a lot of experiments to try. One idea is to "prime" the converter with a charge of high voltage static. Another is to investigate the cavity of the completed pyramid with a simple electroscope[google it] Not long now to copletion, work permitting.
Pontifex
Quote from: bobinaccounting on December 17, 2007, 11:47:07 AM
Well, that is basically the prototype of a parachute by Leonardo da Vinci.
First you need to find the centre of gravity of each four gypsum boards:
>> The center of each gypsum plate (Mittelpunkt einer Gipsplatte) is
>> located at 1/3 of the height of the pyramid ca. 23,6 cm above the
>> base. NOT at 1/2 the height.
Now join these points this way: http://www.overunity.com/index.php/topic,695.msg63739.html#msg63739
Pontifex
neptune
Can anyone tell me the origin of "Skizze 2". Was it drawn by or for TT? The reason i ask, is that it shows the 2 coils covering nearly the whole of the vertical side-pieces of the copper frame. If we now refer back to the photo of the converter shown on page 1 of this topic, [I know this is not the v6] the coil is wound closely[adjacent turns touching.] So again we have conflicting info. Spacing of turns may be important because it effects the inductance of the coil. If the coil is to be close wound, its hight will be about 9x2,5=22.5mm. so there is the question, how high up the copper tube to place the coil. {My guess would be down the bottom where the wet sand meets the dry sand, in other words, the coil would enclose the botton of each graphite rod.] We have had people complaining about people being unable to follow plans, but this is just one example of ambiguous information. The moral is , if is does not work, there is always something else to try. A photo of v6 would have answered many quesyions.
