First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
tak22
Has anyone joined this group?
http://tech.groups.yahoo.com/group/pyramide-project/
Is there anything of interest/value going on there?
Is Thomas in support of it?
tak
jeanna
Quote from: Pegasus on December 17, 2007, 06:18:21 AM
@Jeanna.
Its not clear to me if you have exposed the sand to the center of the pyramid.
Not yet. That was just my control!   I was surprised and came here to see if anyone else got this and while I did the voltage rose steadily to 0.090v and then finally stopped. Also, I was getting impatient and wanted to set up a pyramid so it could begin "charging the sand" and I noticed that the voltage was beginning to drop and was at 0.088v. Unfortunately I touched the meter and the charge changed a lot, so, I just put the jar of damp sand into the pyramid to charge. BTW this is a pyramid I made from poster paper a while ago. It is not official v6, but, you know, I have to try it. ;D
Quote.
If you have the possibility,try to put into the wetted sand a sheet of aluminium and one of copper,and measure the output,and compare with a test control outside the pyramid.There was rumors in the past about the strange effects of these two metals subjected to the energy of the pyramid..Maybe is true.
Regards,
Cyrano.
Cyrano,
Would you please explain that thing with the 2 metals again? Do you mean to use 2 different metals as leads?
jeanna
jeanna
Quote from: Walter Hofmann on December 17, 2007, 05:56:40 AM
Hi all.
I had a big surprise yesterday I had to take the converter apart and start over because I brook one of the graphite rods. now I empty the sand totally dry out the pipe and started over filling with sand then putting the two new rods in fill up the pipe and closed off, fill saltwater. then I put it back in to the pyramide frame insulated at the same spot like before and to my surprise the voltage reading rods to pyramide frame showed only 0.004V. I added a bit more of the saltwater nothing changed. the first setup what had exactly the same material for everythings and even the same amount of saltwater showed right a way 0.231V fluctuating to 0.482V.
this is very strange.
did somebody expirience similar things?
please post it or send me PM
thanks and greetings
walt
I don't get it. Is there something we are doing wrong? Even you, Walt with a converter set up. Didn't Thomas get more voltage? (My eyes couldn't take anymore reading at this point but)  I think I remember that Thomas was getting 9 volts with the converter. That is a whole order of magnitude greater than anything here. I think he even warned us to be very careful because of the power involved. ???
Is there anybody getting over 1,5volts?
jeanna
Walter Hofmann
Hi all
I just wana clear up I dont have the capacitor or the coils hooked up this comes next. I still oucld not find the real reason why this converter failed. but I did find out that the sand if just loosly fill without carefull compact them ( a tapping on the vertical pipes will do it) will shrink at the horizontal portion ( between the two hols) after filling with saltwater and the sand from the vertical portion will not slide down what means there is no connection with the sand anymore thats maybe one reason why it failed the second time.
I also believe that on the description from TT is something major missing how he did get the higher voltage but I will see after connecting all the parts what's happen then, maybe I got a christmas surprise. 8)
greetings
walt
Quote from: jeanna on December 17, 2007, 04:14:46 PM
Hi all.
walt
jeanna
pese
Quote from: Walter Hofmann on December 18, 2007, 05:13:24 AM
Hi all
greetings
walt
Hi all.
walt
jeanna
The 9 volts will start after  2-3 minutes later (after the aprox 0,6 volts are there.
)BUT
the pramide must be in earth-magnetic orentation
the shilding walls (like gypsum) must be attachedon sklett of pyramide.
the converter WITH the capacitors must be finished and sit in the right place
Pese
