First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
pese
Quote from: neptune on December 20, 2007, 04:11:21 PM
@pese, who is Dr Pajak, and where can we see what he said. did I misunderstand you?
Google find all.
IF we use " good think about " KEYWORDS
as used:
http://www.google.de/search?hl=de&ie=ISO-8859-1&q=pajak+150m+pl+poland+pyramide&meta=
THAN CLICK at: (in Cache)!!
also it exist an patent (from other inventor)  that use outside (of pyramide) coil !!
and the model ist fixed between to plates , that contains some 10 Kilovolts in Volage. (no ampere-age ,= no power)
(Static voltage can be used , and is easy to
produce them.
also cacade "ionizer circuit" , tgat worke an line voltage and produce so, 10Kvolts can be used.  Link needed?
Pese
Added:
http://energia.sl.pl/   Dr Pajak Poland
I believe that  this from TT  is the best way
to experiment withthem , to have first results.
G.P.
Walter Hofmann
hey guys
dont let you distrat from all this not realated posts I think we should go on or not but dont react to such distracting posts anymore.
lets move on and report your results bad or good, it does not matter maybe somebody else had the same expirience and found allready a solution.
greetings
walt
georgemay
Quote from: Walter Hofmann on December 20, 2007, 06:00:23 PM
I got today PM from a fellow builder who's pyramid is acting exactly like mine:
The same things happened with mine pyramid! Mine collector had 0.52VDC in the beginning, and after two days the output was fluctuating between 0.001VDC and 0.002VDC and now it is zero!
George
jeanna
Quote from: georgemay on December 20, 2007, 06:52:49 PM
George
me too. I have not got past the sand in the jar pre-experiment. I got some hopefull voltage for a control but now after 3 days inside the pyramid the voltage is down to 0.013v.
Thank you for posting your results george, you have saved me a lot of fiddling time.
jeanna
Walter Hofmann
Hi guys,
I had the same results after rebuilding my first converter you remember? I reported this now it did lay just on my bench for the time and yesterday I put it in the pyramide frame just to see and  I tell you it showed some voltage again and even in AC it showed this time 0.23V steady and in after turning it side wise DC 0.15 to 0.38V. and remember also that my converter had nothing on it no capacitor no coils what I believe is happening that the initial power created in the copper pipe and the graphite rods did run down because this energy is just needed to support and excite the whole setup to pull in and probably increase the output.
I would say just let your converter sit for some time outside the pyramide and then try it again and also try to turn the converter without turning the pyramide and watch the DVM.
over the week end I will try to make a video was just to busy.
greetings
walt
