First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
duff
Quote from: Megla on December 24, 2007, 04:59:47 PM
Can anyone conntact TT?
Some of us have sent him pictures to prove our construction as he requested but I have gotten no response from him.
Don't know about the others....
Megla
By us is 0:45. Jesus has come.
It is very strange, that TT talk no more. Maybe is this Pyramid yust another trick?
However for now Georgemay hunt yust local radiostations.
duff
I've been experimenting trying to find a good method of connecting the capacitor plates. What has made it difficult is copper readily absorbs all heat you apply and I was having a hard time getting enough heat in a localized spot to solder the connecting wire.
Here's what I've come up with.
First my plates are staggered as TT show in the sketch. I staggered them 3mm  but that is cutting it really close for this technique. If I did it again I'd go 4 or 5mm.
I drill a 1.3mm hole in the upper corner of the plate. This aids in getting the localized heated area.
Then turn that corner down so when I heat it the solder won't run back onto the plate and short against the adjacent plate. I then heat it with a butane micro torch (no solder tip) and when hot enough push a little solder into the hole (wire already in place).
Here's a picture - If someone has come up with something better I'd love to hear it.
Also here's a picture of my copper tubing assembly. What I've done is thread one end of the #10 wire which I am using to support the carbon rods. I've used flange bearings and nylon hole plugs to issolate the wire internally. This allows me to fasten the coils to the threaded wire with washers/nuts.
-Duff
Edit: Completed capacitor: 268pf
prohexima
QuoteIn 1986, two French architects used electronic detectors inside the
Great Pyramid to try to locate hollow areas. They found that below
the passageway leading to the Queen?s Chamber was another chamber
3 meters wide by 5 meters. They bore a 1? hole and found a cavity
filled with crystalline silica (sand). They were not allowed to do any
further digging. No entrances to these areas have yet been found.
This sand was analyzed and found to contain more than 99% quartz
that varied in size between 100-400 microns. This kind of sand is
known as musical sand since it makes a sound like a whispering noise
when it is blown or walked on. It appears that this sand may come
from El Tur in southern Sinai, which is several hundred miles from
the Great Pyramid. Why would this type of sand be brought in from
such a large distance and placed in a sealed off chamber in the Great
Pyramid?
from the book "the complete pyramid sourcebook"
very interesting for me.
pg46
Great workmanship there Duff.
Keep up with the good effort.
