First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Walter Hofmann
Hi tinu,
no there is no connection at all from the converter to the frame or negative or ground at all.
greetings
walt
Quote from: tinu on December 26, 2007, 05:12:02 AM
@Walter
Very nice setup. Congratulations!
(I might have one question about the right coil ? but that?s for another time)
Regarding the movie:
It seems like you?re having an electrical contact between the tubing (the core) and the central pipe and further to the pyramid frame. If this is the case, you basically measure the electro-chemical potential of the left graphite rod in respect to cupper in salt water, which is around 0.5V (it can go to 0.7-0.9V in certain circumstances). Please check it.
Many thanks,
Tinu
vipond50
Hello Walter, Nep, Tig, ect.
Sorry if i missed someone
@  Hope U all had a Very Merry Christmas
In all the research in this does anyone recall if Thomas stated that his device ran 24 hours/day or only part of the day or day light hours?
Does anyone know if he tested the unit with all the light off?
@Walter - Yes watched & listened to your vid (thanks) and did note the tak, tak  and a pulsing sound, very consistent sound almost like breathing. The noise also reminded me of the shuman(?)effect i have heard in the very low frequencies.
If possible can U do another video following the procedure that u did and see if the audio effect is present? U do not need to post it, but would be interesting to see if the effect is still present.
@ TIG or anyone - Have U done any work in the VLF audio range of the Earth atmosphere?
skywatcher
Quote from: Walter Hofmann on December 26, 2007, 04:39:51 AM
what is strange on the video is the noise there was nothing running you can hear my odem and there is this strange tak, tak tak, what I did not hear as I took the clip.
This noise is strange. Does not sound like RF interference of a mobile phone. Were there other electronic or communication devices present ?
Is the converter electrically isolated from the pyramid frame ?
Is there a change in the voltage when you mount the gypsum boards ?
TT mentioned that without the gypsum boards, you would get only a few mV.
Do you still have the effect that the voltage changes significantly if you rotate the pyramid ?
Such changes would prove that the voltage is not from a galvanic source, but due to an outside source.
Brazing / silver: This brought me to the following idea: maybe someone could try to silver-plate the copper tubes (or use silver tubes, but i think those are hard to find ;)  ). Maybe the silver plays an important role.   ???
neptune
@All. Did some quick tests today, trying to detect Walts, Tak Tak sound from the pyramid. Using the pyramid with all 4 gypsum boards in place, I tried a portable radio at the focus , tuned to varios frequencies in the Medium[AM] band, and also VHF band[88to108Mhz]. Nothing heard. This is of course not conclusive. "Absence of evidence is not evidence of absence" {James Randi] Can some one explain how to access Walter Hofmanns video? During above tests the onle thing inside the converter was the radio and some wood blocks, no converter.
tak22
For those not finding power in their pyramid, here's a guy who says he did, but then got scared of it. ???
Maybe you can repeat his experiment and improve on it.
http://www.youtube.com/watch?v=P7VN6B2GjVI
Edit: More info on Les Brown and his pyramid experiments http://merlib.org/mirror/keelynet/energy/lbrown
tak
