First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
georgemay
Quote from: Walter Hofmann on December 31, 2007, 05:24:36 AM
Hi george,
this is what I did first outside the pyramide but there was no charge at all.
greetings
walt
Hi Walter,
It looks to me that it acted exactly like battery I had for some time in the pyramid.
I remember  that TT  was explicitly saying that to much of salt water is no good.  When I was injecting salt water, in the beginning it was going in easy.  Then at some point sand was saturated and I had difficulties to inject more.  Since I haven't seen it come out through the other hole I kept injecting.  Then I saw a drop forming on the other side.  At that moment I stopped.  Now I am reassembling collector and what I found out my entire sand is saturated real well with salt water.  That might be bad.  It took me about 15 minutes to see that drop forming on the other side.  I might rushed to much to inject the salt water.  This time I am planning to get it really slow and easy.
I want to hear others experience with it.
George
neptune
@georgemay. I think tat the level of saltwater is a real problem. I think that TTs method gives unpredictable results, due to capillary action. Experiments with  a glass U-tube might allow you to work out the exact quantity of saltwater to fill a given U-tube to a certain level. I asume that TT did not do that , so no one, including TT knows exactly what level he filled his tube to. Perhaps the answer is to have some method to feed in  the saltwater at very low pressure by gravity, so it takes maybe 2 hours to fill. This is definitely one area where we are fighting in the dark. TT seems to say that if too much saltwater is injected, it will drain out in time.
            @ Pese. Please give a short translation of your last post
magpower
Been busy trying things out and give you all a update. First of all I
tried many times using TT diagram and still no real output or not a
sign. So yesterday filled the U tube full of sand and same results.Nothing
Then thought about testing each part out, so cut 2 copper tubes again
130mm long and cap one end.
1. 120mm, 4B, 14ohms. Filled with sand and put a certain amount of
water/salt, the voltage went up very fast to .5v
2. 120mm, H1, 58ohms. Same thing and this one climbed very slowly and
got to about .4v.
So having said this I drew out TT ckt on paper and really to me does
not make sense. My thought is really its 2 small wet battery cells
with a open ground, copper U. The top of the graphic rods are positive
but not a complete ckt. Thomas please explain!
So re wired it as a L/C tank ckt, meaning cap and 2 coils on each side
in parallel and also batterys, and outside U tube is now connected to
frame. Then last night is was jumping around 85mv and and down and I
keeped touching U tube, then volt meter locked in at 86mv and climbed
up to .128v right now. So I think the pyramide has charged the cells
to this voltage, and did check this and both right and left are .128 each.
Today maybe want to refill U tube and not to top this time. I might
get flamed for going and changing TT ckt but until he comes forward I
will keep trying this out. Not to say this is right but we have never
seem a V6 work just V4. So who knows. Just everyone should follow V6
first and then try something else.
Happy New Year
Wayne
georgemay
Magpower,
If you rotate pyramid slowly can you see a drop or increase in voltage?    If power fluctuates then pyramid is doing its work. Orient the pyramid to its highest output and wait few hours.  You might be real close to success.
George
magpower
Just found out another little thing. Right now I took out left coil, so just right side in coil and center cap. Now the output on left graphic rod is only hooked to volt meter and climbing right now to .138volts and going up. I won't rotate nothing yet, just will watch it. I think 2 coils might be loading the L/C ckt to much. I don't know but this is best I have got so far, just hope for new years I get zapped off it.
