First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
pese
It shown like:
IF the output Vortage are different , so
so cil is CW
and CCW  turned ...
so that experiment say , some "thing" inside the
device is working , that is  NOT to explain
with "galanic cell".
Pese
Walter Hofmann
Hi all ,
the first coils was both wound CW and this brought some good results, after all said that the reason that I can not get more then the max 0.845V is that the are both the same direction, I wound a new one with CCW direction and put it in the same setup like before and it brought nothing more then ).007V.
overall the results from the old set up has nothing to do with galvanic cell because if a galvanic cell would be involved the negative pool ( the copper pipe frame ) had to be connected  to the negative pool of the pyramide or at least to the negative of the DVM.
today I will finiosh the V4 version and will see what is going on here.
greetigns
walt
Quote from: pese on January 01, 2008, 05:19:16 AM
It shown like:
so cil is CW
and CCW  turned ...
Pese
Walter Hofmann
hi all
I need to correct the portion with the plate connection, because I believe this is verry importand.
what was connected to the middle capacitor was only one connector was connected the other one did float or better not connected to anyhtings at all.
what would mean the middle cap works not as a capacitor more like a antenna, if this is true then the whole thinking of the setup changes totally
greetings
walt
Quote from: Walter Hofmann on December 31, 2007, 04:45:06 PM
OK guys here we are,
today I did put a rewind coil in the setup and connected the whole thing back to the description from TT and I tell you there is no output at all it jumps to 0.007V and thats it. I even did finish the big capacitor and put him in no change.
I also did clean out the whole thing and started new, nothing again.
now can anybody tell me what is wrong on this picture, the old coil version did bring up something even if it was not to much, the recommended version where many believed is the only what works does not work at all. the latest change with the parts from V6 but connected like V4 ( at leasdt as far as I can identify) did charge a 1 farad booster cap up to 0.845V.
now I am very courious what happen when I have finished the V4 version and put them to the test.
Now answering some question about the setup what charged the booster cap: the strange thing was that only the lower plate contact was connected the other did float ( nothing connected at all).
the whole copper pipe U frame is just floating no connection to anythings at all here too.
the pyramide is only closed on three sides because if V4 real it was open on one side too and did bring the power to run the fan.
what I also found out by dismanteling the V6 version was that at the point of filling where the small hole is on ether side is a empty space between the bottom U and the vertical pipes where the graphite rods are it is about 1/8 inch where no sand is what means no connection between the bottom and the verticals this is due to the way how the sand should be filled in like TT described it should be loosly filled in now when the saltwater is injected the bottom portion denses and the moisture from there climbe's up the pipe wll and saturate the bottom portion of the vertical pipe sand where the bottom portion shrinks more and more and builds this empty space.
thats so far my expirience. I will report how V4 works out.
greetigns
walt
Walter Hofmann
Hi skywatcher,
I am realy courious what you find out with your setup.
I regards to the cap I had finished yesterday the original endcap and had connected it but the whole setup did not work at all after changing the one coil winding direction.
greetings
walt
Quote from: skywatcher on December 31, 2007, 06:06:39 PM
Hmmm...   ???   This is very strange, but it clearly shows that we have a real (unknown) effect, because if it would be only galvanic effects or something like that, these effects don't care at all about the direction of the coils.
Hopefully i will finish my setup tomorrow, then i can start my own experiments.  :)
Quotethe latest change with the parts from V6 but connected like V4 ( at leasdt as far as I can identify) did charge a 1 farad booster cap up to 0.845V.
Yesterday we talked about using a second cap and you said the booster caps are very expensive.
You could also use Gold Caps. They also have very high capacities, but are much smaller and very cheap, compared to the booster caps.
The Gold Caps have lower maximum voltages, but i think at the moment the typical 5V are more than sufficient.  ;)
Walter Hofmann
Hi duff,
did you read my post in regards to changing the coil winding direction? Till anybody comes up with results from a setup where the coils wind in oposed direction ( because the most who reported here and have the right coil direction reporting that they have nothing) I sai this is exactly what does not work. maybe I am wrong but my test prove's otherwise till now.
greetings
walt
Quote from: duff on December 31, 2007, 01:08:53 PM
@magpower
I have  few suggestions.
Looking at some of your previous pictures (don't know if you current setup is the same), you have would both coils in the same direction and they should be opposing.
Also, try changing the wire size to #10 (2.5 mm), and give it an inner diameter of 25mm rather than winding it directly on the tubing.
Thanks for the update
-Duff
