First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Walter Hofmann
Hi george,
I will try with a totally new copper pie frame setup not using any saltwater at all, and see what is happening then.
because even if you inject just a very small amount of saltwater the capilary action will moisten all the sand I checked this.
greetigns
walt
Quote from: georgemay on December 31, 2007, 09:26:28 AM
Quote from: Walter Hofmann on December 31, 2007, 05:24:36 AM
Hi george,
this is what I did first outside the pyramide but there was no charge at all.
greetings
walt
Hi Walter,
It looks to me that it acted exactly like battery I had for some time in the pyramid.
I remember  that TT  was explicitly saying that to much of salt water is no good.  When I was injecting salt water, in the beginning it was going in easy.  Then at some point sand was saturated and I had difficulties to inject more.  Since I haven't seen it come out through the other hole I kept injecting.  Then I saw a drop forming on the other side.  At that moment I stopped.  Now I am reassembling collector and what I found out my entire sand is saturated real well with salt water.  That might be bad.  It took me about 15 minutes to see that drop forming on the other side.  I might rushed to much to inject the salt water.  This time I am planning to get it really slow and easy.
I want to hear others experience with it.
George
duff
Quote from: Walter Hofmann on January 01, 2008, 06:25:47 AM
Hi duff,
did you read my post in regards to changing the coil winding direction? Till anybody comes up with results from a setup where the coils wind in oposed direction ( because the most who reported here and have the right coil direction reporting that they have nothing) I sai this is exactly what does not work. maybe I am wrong but my test prove's otherwise till now.
greetings
walt
Quote from: duff on December 31, 2007, 01:08:53 PM
@magpower
I have  few suggestions.
Looking at some of your previous pictures (don't know if you current setup is the same), you have would both coils in the same direction and they should be opposing.
Also, try changing the wire size to #10 (2.5 mm), and give it an inner diameter of 25mm rather than winding it directly on the tubing.
Thanks for the update
-Duff
Walter,
TT emphasised the direction the coils were wound but I can understand you frustration and wanting to try something that appeared to show results.
I will begin testing today or tomorrow if all goes well.
If my setup does not work rather than changing TTs design I believe I will start correcting the things that are not exactly as TT says.
I was unable to build this device perfectly. I know I have made mistakes and I know where they are but this was my first build and I know how to do things better now.
Also, there is plenty of room for misinterpretation in TT white paper and we have seen him overlook details.
We also know he was upset over our interpretation. Perhaps the sand fill level was not it.  Maybe next week I will go back through the discussion and look for other possibilities.
-Duff
neptune
Hi everyone. Today I found an hour to do a bit of pyramid work. My v6 converter was complete except for sand, graphite, and saltwater. My completed pyramid is at a friends house 15 miles away, as i have no room for it here. There have been many failed v6 projects, that I am going to try something different. Inside my copper tubing ,I have 2 zinc carbon cells wired in series , to replace the "voltaic cells". I will give this device to my friend tomorrow to be placed in the pyramid for tests. The hope is of course more volts out than in. Future ideas include a close copy of a V4.
@ Pese thaks for the message.
@ walt. you keep getting interesting results. I get the impression that this is not Luck, but a lot of time and effort. You deserve to succeed, and you are not the only one. If somebody cracks this, it will make 2008 a vintage year.
supersam
@walter and all,
i have been following this thread and tt site since the begining.  i have also been following the earth battery thread.  in the earth battery thread and experiments, they have found that using cabon rod stuck into the ground always becomes the positive of the circuit and by using a magnesium rod stuck in the ground this becomes a negative pole.  by running this circuit through a led they are already generating enough power to light the led.  please don't let me take you off track, however,  tt never really finished describing his setup completely.  so we really can't be sure what his setup is.  it does seem to make a little sense to me however if you are using two carbon rods, maybe both actually positive with only a slight voltage differential due to the length of your positve carbon rods why your coils only produce when wound the same direction.  it also makes sense to me that if you also use a magnesium rod, negative, and a carbon rod positive, to form a circuit through your coils that are wound right handed and lefthanded and then ran in series with your capacitor,  you might expect to have a chance, with proper alighnment to get enough power to see if in fact the pyramid is doing anything to enhance this effect.
just my thoughts. kind of got a little discouraged about the actual build when tt pulled out,  since you guys are already way ahead my if someone could give this a try it might get some more of us watchers off our asses.  keep up the good work.
lol
sam
Walter Hofmann
Hi all,
yesterday I finally had the time to move my pyramide out of my big workshop in to my smaler electronic workshop and on the way there I did test the theorie about underground water because I have a underground aquifier running from east to west in about 6 feet depth. the result was no influence on the output of the pyramide at all.
Now that I am in the other workshop where I got more equipment I can also use my oszy its a old one but hey, to see if there is anythings to see on the scope.
I also start tonight tests with the replica ( as close as I could build) of the V4. what still buffles me on this one is the fact that the top bridge including the two vertical pipe's are soldered and only the bottom brifge is somehow riveted, the million dollar question now is how to fill this with sand and hold the graphite rods center and then connect the bottom filled with sand without the sand running out.
I mean on the top to hold the rods center would be possible ( at least thats what I did) if the rods are locked in place by like wax or so and then fill the vertical with sand but then comes the probleme connecting the two bridges together I did it the way that I filled the top part full upside down and the bottom bridge that just the horizontal pipe was filled , then I put a piece of clear tap across the two vertical pipes made them so long that I still could grab them. I put the bottom bridge in a vice and the put the top portion right on top and carefully removed the taps it did work well with a tiny bit of sand runing out. the remaining area of the bottom part will be filled from the overfilled sand of the top portion. but this means if TT made it this way that the top bridge is filled with sand too. I will see how it works out.
now I got my pyramid standing right on the concrete floor there can not be any other influence.
greetings
walt
