First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Walter Hofmann
Hi all,
this is for the guys who took TT's whitepaper to the point and did not get anythings.
I told you guys that I had some output with my old setup ( charging a booster cap up to 0.845V) then some discovered that my coils was wound both in the same direction and they ment this is the reason that there comes not more out. actually what was happen I had made a couple coils some with CW and some with CCW and as I did assemble the unit I grabed two of the same without realising this. now I took the unit appart and put the right one in it and I tell you there was nothing not even a pip ( only 0.003V). then yesterday I put the old one back and it started right a way climbing in voltage all the way to 0.400V.
this shows to me that again something is wrong with TT's white paper. I also had put in the big capacitor which after TT was there only to increase the output.
But there is another story during the etsts I also did connect a 33 ohm resistor between the positive and the pyramide frame and what was happening is that the DVM showed that instead to climbe as negative voltage it did run to 0 but then it starts climbing in popsitive up to 0.390V . I did not trust this DVM and took another one - the same result this was strange.
I still could not figure out why the DVM shows negative instead like TT described should be positive. there is no AC ( only 0.003V)
just to avoid more question my pyramid is sitting now on my other workshop concrete floor exactly in North and three sides coverd with rigips ( like In TT's video shown).
the other part is if I ground the pyramide frame ether with the house ground or a seperate 8 feet grounding pool driven 8 feet deep in to the ground the voltage goes right down to 0.09V.
Like I mentioned before TT said that he did only for security ground the pyramide frame I believe he was concerned that maybe a high voltage spike could acure.
maybe my expireience helps some of you.
greetings
walt
Walter Hofmann
Hi sam,
you are damne right. I dont think that TT doesnt come back because some of us do more experiementing on ther own, he probably has some other reason.
what is also a point is that because there are no information about output value, or picture or video from the V 6 or V12 and the description are not complete ( I see it more as a hint) what should be replicated and compared? the only where are the info in regards  to value picture and video was is available is the V4 but for this there are no detailed data they are everybodys guess.
I personaly do my experiements further till I find or not what we all looking for.
greetigns
walt
Quote from: supersam on January 02, 2008, 10:35:02 PM
@all,
when are you going to figure out that you don't have the information neccessary for any replications of tt, until he finishes, something anything.  look back and take a serious look at what you have.  what a possible frame with alot of unanswered questions about that or at least several ambiguos answers as if no real thought was put into answering any questions except with "you guys are super and doing great, yes" , that must be it this time guys, so whatever you do don't try anything else because you might piss tt off and he will never come back.  START THINKING OF SOME REAL EXPERIMENTS YOU MIGHT DO WITHOUT WORRYING ABOUT WHAT TT THINKS!!!!!!  JEEZ!!! WHAT IS THE PROBLEM?
lol
sam
Gustav22
Quote from: duff on January 02, 2008, 01:34:09 PM
...setback ...
...rebuild ...
@duff
Very sorry to hear about that. But since you are rebuilding:
Did you realize in skizze2 (converter):
the connection to the left (short) graphite rod in the copper-T is indicated with a very thin short piece of wire (thin pencil line), whereas the connection to the right (long) rod is indicated as a very fat line.
Since you are such a perfectionist
thought I'd mention it.
I will alter my setup accordingly.
@Walter
I also experience negative and positive and flipping potentials in reference to ground, depending on if and where I connect to ground. But very erratic and hard to replicate and to make sense of.
I still have not got any "tension" above 300 mV, yet.
money for rope
Nutcracker
Just an observation from an armchair observer... (sorry for not building but resources prevent it)
Regarding the quote below:
Quote from: duff on December 30, 2007, 11:12:44 AM
Thomas states:
The energy pick-up tubing must now completely (however loosely!) filled with quartz sand
This is my personal opinion and it may be WRONG.
When he said completely, I believe he meant all the way to the top of the entire U-shaped structure including the top horizontal piece.
Why - because look at the construction steps that were laid out.
   1. Install left graphite rod
   2. Install left 2.5 mm (#10 wire) coil
   3. Install right graphite rod
   4. Bore fill holes for salt water solution
   5. Install right coil
   6. Install capacitor
   7. Hang unit in center of pyramid
   8. Fill with sand
Assumption: So he must have created small fill holes and allowed the sand to trickle in like an hour glass.
If this is true he has no way to determine the level until it is completely full.
-Duff
The way I read this, is that the converter is built first and positioned in the pyramid before ANY sand is added to the unit.  If this is the case, then there is no guarantee that the bottom of the ushape is filled with loose sand. There may be a void there in the middle at the bottom of the U shape when the left and right sides are filled with sand. (not counting what ever sand spills into the bottom from the sides being filled)
Again, this is just what is jumping out at me as a non-builder.
Nut
IndianaBoys
Not sure if any of you have seen this recent video on YouTube:
The Physics of Crystals
http://www.youtube.com/watch?v=AfbobxXuu0g
You will hear in this promotion some experimental work that was done with zinc inside a pyramid.
His pyramid turned his zinc into calcium powder.
One clue may be what frequency the pyramid you are using (angles) is set to.
For instance, some believe that the angles of the Cheops Pyramid is set to resonate at 32,768 khz (limestone/calcium)
Maybe try to use a calcium type of battery with the addition of a smaller pyramid in each corner as mentioned in the above video.
Lets make this an electrifying year!
IndianaBoys
