First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
supersam
@walter and all,
now that that is understood, i still think that the biggest problem i see is you don't have anything that connects to the balance of the circuit.  the copper is still going to function as a positive the same as the carbon.  think about switching one of your rods for a negative, either zink coated iron or magnesium. then you have a circuit!!!
lol
sam
Quote from: supersam on January 01, 2008, 03:10:33 PM
@walter and all,
i have been following this thread and tt site since the begining.  i have also been following the earth battery thread.  in the earth battery thread and experiments, they have found that using cabon rod stuck into the ground always becomes the positive of the circuit and by using a magnesium rod stuck in the ground this becomes a negative pole.  by running this circuit through a led they are already generating enough power to light the led.  please don't let me take you off track, however,  tt never really finished describing his setup completely.  so we really can't be sure what his setup is.  it does seem to make a little sense to me however if you are using two carbon rods, maybe both actually positive with only a slight voltage differential due to the length of your positve carbon rods why your coils only produce when wound the same direction.  it also makes sense to me that if you also use a magnesium rod, negative, and a carbon rod positive, to form a circuit through your coils that are wound right handed and lefthanded and then ran in series with your capacitor,  you might expect to have a chance, with proper alighnment to get enough power to see if in fact the pyramid is doing anything to enhance this effect.
just my thoughts. kind of got a little discouraged about the actual build when tt pulled out,  since you guys are already way ahead my if someone could give this a try it might get some more of us watchers off our asses.  keep up the good work.
lol
sam
atlantex
Quotethink about switching one of your rods for a negative, either zink coated iron or magnesium. then you have a circuit!!!
that would be a simple dirty chemical reaction in combination with the saltwater and sand.
I assume that's not what we want...   :P
atlantex
Walter Hofmann
Hi all,
I wana say in regards to galvanic cell it can not function as such because a galvanic cell allways needs two connection to the same cell one pos. and one neg. right? now even if the copper frame works as such second pol it is not connected to anythings totally insulated from the negative pyramide frame.
now I did some more testing. I had to take out the center cap because I broke one of the connector her I thoughd why not connect the two coils in series ( connect both together instead of the capacitor) the graphite rods still connected to ether of the coil ends, both coils are CCW wound. then put one connector from the big capacitor to the right side and the other pol from this capacitor to the pos. of the DVM and I was totally surprise that I had instant 0.34V even that the cap. was totally outside the copper frame. with just a bit turning the copperframe in ether direction I could see changing of the voltage up to 0.1V the highest was if this frame was about 3 degree eastward but the pyramide frame was set to excatly north. the center of the copperframe was set to 220mm hight from the base.
the out put is allways negative on the DVM.
greetings
walt
supersam
@ walt,
i think what you are seeing is a result, however small of the earths magnetic fields running across your coils, just because the earth is spinning in a magnetic field!  you have so little voltage how can you asume anything else?  other than maybe "the grid", jezz i can get more voltage out of my laptop's stray capacitance!  what the f---k?  how can you possibly consider such voltage as even pertaining to anythin other than the earth?  if you can stick your two carbon rods in the ground, one two inches and one three inches, and get not only votage but amperage out, how in the hell are our fifty dollar pyramids, helping a damn thing. pardon my french!  the real question is, DOES THE PYRAMID HELP THIS ACTION?   screw what tt said!!  obviously something is wrong with that picture.  I SIMPLY DO NOT KNOW WHAT TT DISCOVERED, BUT IF WHAT HE HAS POSTED SO FAR IS ANY INDICATION, I CAN'T SEE WHY IT WOULD BE A PROBLEM!!!!
lolo
sam
ps: so since you have the hardware now, why not experiment on your own?  seems logical!!
Walter Hofmann
Hi sam,
you are very confusing to me did you read my posts? then you should have realized long time ago that I do my own experiements but report back the results good or bad, what about you?
bitching around does not help and just to go what TT said ether.
greetings
walt
Quote from: supersam on January 04, 2008, 09:14:24 PM
@ walt,
lolo
sam
