First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Walter Hofmann
Hi neptune,
follow the wire on the left side from the top the righht graphite rod wire goes over a 1 turn to the left graphite wire is connected there to a black wire what goes in a kind of flat 5 tunr sandwiched between the cap plates on top and to the upper 5 turn coil the other end of this coil is directly connected with the 20 tunr coil on the bottom copper pie and from this coil other end goes to the terminal block on the left side wich connects to the big cap. the lower portion of the center cap is connected to this terminal too I think. the big cap has one connection coming from the lower coil and the same plate is also connected to the motor and the meter the other plate is conneted to the [yramide frame , the motor and the negative of the meter ( this is if the whole szenario is tru the two meter wire could also be coming from a outside power source, this would be then the toal fake) this missing lead from the cebntral cap has baffeld me too and I believe it does not work as a cap it works like a receiver and comprimator thats why the black wire on top is wedged between the plates. I will see soon how this works out
greetings
walt
Quote from: neptune on January 07, 2008, 01:19:59 PM
@ supersam, we have no alternative except to take the long road, unless of course you know a shorter road, in which case, please tell.
              My next step is to replicate the v4 as closely as possible. Looking at the photo on page one of this topic, There are 2 areas of confusion regarding the circuit. First is the area near the blue object on the left side of the copper tube. we now know there is a reed switch here operated by a magnet, and both of these are unnecessary. The other area is identifying the 2 output leads of the capacitor. [ note that the drawing on this page shows only one out put lead. One lead is obvious. A black wire exits the cap at top left and connects to the 5 turn coil via a terminal block. The
only other output lead is the bare wire at cap bottom left. I think it connects either to the reed switch and thus to the left graphite rod and the converter output. A second, less likely possibility is that it connects to the copper frame near the reed switch.
     Thus the circuit is; 2 graphite rods connect together and the output is taken from the left rod, another wire from left graphite goes to the big coil then the small coil, through the cap and back to the left graphite[ or possibly to copper frame] Opinions welcome
The Eskimo Quinn
Haven't read through all the posts, but i did notice everyone using perfect pyramids, without getting myself into another long conversation, My only contribution is that this started with the Egyptians, and considering we still to this day cannot build a structure 30 stories tall without a variance of 4 inches from centre top to centre bottom, with laser lines, and the pyramids are less than an inch out, they clearly were masters of design. that being said the pyramid angles on the perfect Egyptian pyramids is not a 45 slope but in the 50's forget off the top of my head, but it may be crucial.
Good luck
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
neptune
Hi Walt, and thanks for your input.However I am inclined to agree with Duffs post on the Yahoo site when ha says that the black wires visible at the upper corners of the central cap, are just to connect individual positive and individual negative plates. You idea of a coil interleaved with the plates is feasible. As always it is best for us all to try different ideas.Re the V4. Assuming the central cap plates are sized as in V6 [ and there may be only a total of 6 plates in the v4 cap] then the copper frame is considerably taller. we do not know the length of the graphite rods in v4, and there appears to be no saltwater drain holes. I am experimenting with a test tube full of sand, to try to create a formula to determine what quantity of saltwater will wet a given volume of sand. Thus I can put the saltwater in before the sand.
            Is anybody satisfied,or not, that they can demonstate any effect , however small, that happens inside the pyramid, but not outside.
           Also does anybody who has a theory about the origin  of "pyramid" energy" have a theory about the shape or direction  of the field, rays, etc inside the pyramid. The more we find out, the less we realise we know...
The Eskimo Quinn
Sure,
The origin of the theory the pyramids provided some form of current was made by one of the archeologists in the late 1800's early 1900s when he kept getting zapped by small electric shocks from the wine bottle from which he was drinking directly.
The theory was at the time that the wine acted like vinegar creating some form of battery, naturally batteries have to be charged, eluding to the possibility there was some form of magnetic or electrical field, this was further strengthed as a possibility when the clay jar batteries were found, with the terminal connections.
I am unsure if reproductions of the jars were ever made to test them, they are in one of the museums.
I personally believe that the effect is actual, based on the measurements of Giza etc having relevent measurements to the circumfrence of the earth, how they knew this is unknown, but i am sure that it is relevent hence my previous note on the angle, That being said, i suppose i should have noted that point in repect to the other dimensions as your starting point for size being scale.
I don't believe they invented an incandescent bulb, so my question was never did they work, but what did they use them for.
sorry bout the spelling, but the site spell checker doesn't seem to be working all the time lately, and time is more precious to me than grammer.
The Eskimo Quinn
these may be helpful to get your measurements and give you also some insight as to who else used them
http://cycle-of-time.net/43200.htm
http://www.gizapyramid.com/newton.htm
