First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
blubbino
Quote from: duff on January 08, 2008, 04:54:07 PM
Then today I thought I would remeasure the frame and found it 3mm out of square
Hi duff,
3mm Winkelfehler solltest Du ohne Probleme noch mit der Hand ausrichten k?nnen. Setz die Basis mit der Ecke auf den Boden auf und dr?ck feste  drauf. Wirst sehen, der kommt ;)
Ansonsten zieh in den Ecken, die >90? sind, nochmal eine Naht in der Innenecke durch. Beim Erkalten zieht die Schwei?naht den Winkel nochmal zusammen. Ma?kontrolle mach ich bei solchen Arbeiten grunds?tzlich nicht mit dem Winkel, sondern ?bers Diagonalma?.
3mm.... pfffffffff.....w?r doch gelacht...:D
duff
Quote from: blubbino on January 09, 2008, 04:59:03 PM
Hi duff,
@blubbino,
Thomas said: "The ground shape of the pyramid must be absolutely square."
3 mm is not much but when it does not work I have to look at where I made mistakes.
@neptune
Yes I could cut the frame and try to correct the mistake
Thanks guys for the suggestions. I will try them.
-Duff
duff
After thinking about it over night I've decided that I want to rebuild the frame. You might think this is pointless but I have some things I want to try which no one else has done (that I know of).
Thomas stated that the V12 corners should be cutout and the diagonal should be 1000mm from the bottom of the cutout to the apex.
CLaNZeR and I discussed this in the TPP-Project forum and I think that's why he went with angle iron. It basically accomplished the same thing without making the cutouts AND the gypsum lies flat against the diagonal. With the cutout the gypsum does not lie flat against the diagonals.
I built a modified version. I inset the diagonal on the top of the frame so that it had the same angle as if it were setting in the bottom of the cutout and cut it to a shorter length. Effectively it was 1000mm from the bottom of the frame to the apex and the gypsum did not lie on the diagonal at the bottom but my diagonal was not 1000mm.
So, while you guys work on other aspects of this device, I want to rebuild the V12 frame as Thomas specified, with the cutouts in the frame, simply because it has not been done (that I know of). Also, I want to strive for more precision.
When you read the white paper on the V6 it sounds easy to get this device working. You don't even need a compass. Just slowly turn the pyramid into the north looking for a voltage rise.
No one has seen this effect that is willing to talk about it.
-Duff
libra_spirit
Hello group,
I do not know how many here are sensitive to pyramid power, or meditation, but I will offer our discovery as it may be somehow applicable to the effort happening here. It is not my intention to divide this group into offshoot efforts, but only offer our current project data and discoveries in hopes that more minds may find answers faster if all knowledge is openly shared.
http://magnetism.fateback.com/LightTech.htm
I have my own ideas now on how pyramids generate power from Light, and the URL shows what we have been doing.
http://magnetism.fateback.com/index.htm
Thanks,
Dave L
