First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Earl
Quote from: Walter Hofmann on December 10, 2007, 04:41:13 PM
[snip]
any how what I am wondering is if there is allready a seperate group who did get via PM the plans because they dont show up here anymore ( ovidio and some others)
[snip]
greetings
walt
perhaps by private email, but not PM, since PM on this forum does not allow any attachments.
Earl
Pontifex
It must be solution A as the confirmed step-by-step instruction says that the angle needs to be 90? degrees:
Greetz, Pontifex
Pegasus
Quote from: Earl on December 11, 2007, 10:43:28 AM
[snip]
[snip]
greetings
walt
maybe..... ;D
magpower
Thanks Pontifex
Will do
I burned off the wood from my pencil and cut one too 90mm and the other 95mm. They are 5mm wide and about 2mm thick, not perfect. I took a ohm meter and got approx 20 ohms from end to end. I assume using 2mm rod this would be less but will try this first.
Pegasus
I have conducted  an experiment to see if something happen.
Half glass cup was filled with quartzsand and exposed to the focus of the pyramid for a couple of days.Than I put in the glass some tapwater to make the sand just wet.I inserted the two  graphite electrodes and I connected my meter on voltage reading.The meter jumped at the end of the scale!.But was less 2 Volts....The test was reapeated some time later but this time the meter showd few mV at every reading.Again,after some time the reading turned to zero and not resuscitated..... Is it a real proof od something?.(The wet sand not exposed to the pyramid dont show any voltage.)
Cyrano
