Besslers Wheel?
Started by Alexioco, March 05, 2009, 06:28:00 PM
grayone
Quote from: Alexioco on March 09, 2009, 03:32:25 PM
Ok, sounds good, I will have to buit the parts yet though, I think the wheel has a good, do you think mroe weights are needed though to make sure that enough weights fall in order to lift the two weights at seperate times?
Alexioco; I like what you said, and wish you lots of luck on the build. More weight for each action.
Alexioco
Quote from: grayone on March 13, 2009, 04:58:04 PM
Or what if I raised the weights at the bottom by another manner? I'm not sure
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
Alexioco
Ok, here is the latest information on my wheel design...
There has been a design change,
As you can see, the inner ascending weights are flipped up and over the small "flip wheel" at the top of the wheel to take a position with the rest of the descending weights in order for the next inner ascending weight to be flipped up and over.
In total there are 16 weights, 8 inner ascending weights and 8 outer descending weights. There has to be alot of weights so each weight can be flipped up and over the "flip wheel" with ease. I have tested this roughly by sticking the 15 weights in their positions and attaching the 16th weight onto an arm then letting the wheel go and watching it flip over a pencil (used as a flip wheel) the weight flips over weather it gets a run up or not. Now lifting the weights up at the bottom is the next challenge, I have two ideas in mind:
1. Arange 17 (odd number) weights so that one weight flips up at the top, then just after one flips up at the bottom (via another "flip wheel"), the top and bottom weights could not lift at the same time as it would be to much on the wheel.
2. Cause the bottom weight to flip up into the axle by some other means
Help would be much appreciated, thanks :)
Alex
AB Hammer
Greetings Alex
I am still thinking and I might be able to think a little clearer after I finish with this event for my armour.
Alan
AB Hammer
Greetings Alex
Next week, I will finally get back to a wheel work schedule. At least one day a week. ;D
Alan
