This must work! Altering magnetic field without cost. OU or not?
Started by Low-Q, March 07, 2009, 08:38:50 PM
Of course a rail gun works with DC power it's not the sudden burst of magnetic field that causes the acceleration it's the presence of the magnetic field, when will you get this?
http://en.wikipedia.org/wiki/Railgun
Low-q I think I'm going to stop posting in your thread or else people will call me jealous again  ::). You keep making up these pointless remarks that I'm starting to think you are deliberately selling your disinfo. I asked you to do some research and you didn't do squat. But you act like you know what you're talking about while you clearly don't. Maybe one day you will go "aha now I see what he meant". But that day isn't going to be soon it seems.
Low-Q
Quote from: broli on March 17, 2009, 07:24:33 AM
You're right, I was confusing this with a coil gun or something.
But anyway, if you bend the rails around to make a rail circle, the projectile will loose its magnetic reference bacause the magnetic forces that is pushing the magnetized projectile away, will in a closed  rail loop be pushed equally from both sides.
The projectile just want to escape from the magnetic field built up in the straight rail- and projectile conductor. And it can because there is no magnetig field in front of the projectile that stops it. In other words, the magnetic field only occour in the closed current loop, but as there is no current flowing through the rails in front of the projectile, no magnetic field is made there. The current loop is limited by where the projectile is present, so to speak. maybe you can almost close the rail loop, and hope that the projectile is jumping over for a new round. If you can do that with permanentmagnets, it might be worth trying it. Looking forward to your results.
br.
Vidar
Low-Q
Quote from: broli on March 17, 2009, 08:27:32 AM
Read this thesis and open you mind...
http://www.df.lth.se/~snorkelf/LongitudinalMSc.pdf
Interesting reading, and I try hard to be open minded.
The thesis is however not very related to permanentmagnets, and how you can utilize the properties of a railgun by using permanentmagnets instead. The rail and the projectile is a coil, an equivalent of one permanentmagnet that expands - not more. A long permanentmagnet magnetized through thickness, like a railgun is, if you break it in two, those two parts will be forced apart - almost like the railgun works. In fact a permanent magnet want to pinch in the direction of magnetic lines, and expand angular to the magnetic lines, so to speak. So if you are going to make a railgun-motor with permanentmagnets, i really don't know how you are going to make that working as the projectile in a railgun works like a monopole in the circuit. And as far as I know there is impossible to make a monopole with magnets.
You can allways try to close a magnetic loop in the rotor or stator, so you get all the lines in a circle in order to simulate the magnetic field around a wire with current flow, and put that circular magnetic field between two magnets attracting eachother. In my mind it would work, but after an experiment with that, it didnt work at all.
I once did an experiment like in the picture below.
Anyway, I feel we are going quite off topic now, and I blame myself for it - even if it is interesting discussing motordesign with you :)
Br.
Vidar
arringtj
Go ahead a build your idea like an aircraft radial piston engine. I like your concept and have my own I am in the middle of building using the radial concept, but not with your "cancelling" idea. Just build it! Good idea.
Thanks,
Jeff
