Oscillatory leverage...
Started by iacob alex, March 08, 2009, 12:18:53 AM
iacob alex
    ....at   www.geocities.com/iacob_alex   then click on "Some_Drafts"/text029.jpg
             All the Bests!  /  Alex
iacob alex
                     Hi !
    The proposal  "Oscillatory leverage" (see up ...at "Some_Drafts"/text029.jpg ),is a simplified design,that can be tested easy.
    It aims to show ,if we can make some more "steps",on the line of Milkovic's pendulum with a lever arrangement.
    Milkovic uses s plain swinging motion,due to pendulum fulcrum's displacement along a limited arc.
   The first step can be this: to experiment a different swinging motion,due to a full rotation (360 degrees) of the pendular mass.
   In this situation,we employ a Milkovic's scheme, without any change.
   The second step,requires a change: a single pendular mass,becomes a two pendular system(a switching long arm-short arm scheme).
   The hope,is to get a "self"...
iacob alex
   ...is a simple composition of a mechanical pulsatory oscillator(the "red" and "green" equal masses,play the "long arm-short arm" game,intended to become "self"),and of a mechanical amplifier(output>input for a Milkovic's alike swinging arrangement).
      An important fact is that Milkovic introduced a new kind of lever,working in non-linear dynamics.
      A large swinging motion of a pendulum,with a fixed fulcrum,is a "classic" model in non-linear dynamics.
      The same motion of a pendulum,with a mobile/free fulcrum,becomes more attractive and inviting to reconsider the so called "chaos"/unexpected reaction of inertia.
       If Milkovic's device works as an amplifier(output>input),this is the right solution for the topic of this forum,because...in my opinion,the "long arm-short arm" model,can't supply too much power.
        So,as in electronics,for a small signal/oscillation we need some "help"(amplification,enlargement).
         If,by happy chance we have the second step(amplifier),all that we need is a new chance for the first step : a mechanical  oscillator(gravity powered device)
          Take this ,as a personal opinion,only.
        All the Bests!  /  Alex.
iacob alex
.....as a basic concept , can be a "key" to release your mind from the "wheel " image obsession.
Let's make a short visit in a wonderful "garden" of leverage . at :
www.youtube.com/watch?v=xuXdVAxyFXs
Maybe , this Kinetic Art Exhibition , can help you to imagine a manner to change gravity potential in a kinetic one ...as a continuous "self" motion.
Remind that lever is the starting  point of mechanics (statics).
An oscillatory lever ...can be a new starting point (dynamics) .
      Al_ex
iacob alex
.....is a way to imagine a gravity powered device , easy to be tested , if we "copy" the design of an oscillating steam-engine , at :
http://blargh.wpi.edu./~jski/projects/steam-engine/Engine.html
If we have in mind , as a common starting point , a slider crank mechanism :
http://kmoddl.library.cornell.edu/model.php?m=13
...we can develop :
-an oscillating cylinder steam-engine mechanism , playing a repetitive expansion of the steam pressure (we have it...).
-a self-oscillating lever(age)...due to ("self") repetitive "expansion" of the gravity unbalance (we need it...).
  Al_ex
