Leedskalnin
Started by Big, January 24, 2006, 01:40:12 AM
0 Members and 83 Guests are viewing this topic.
cosmos69
CORRECTION:  for number of Vee-Magnets used by the Model-T Fords.
   I had a better look at Ford's Model T history / manuals ...  ( ie. correction re. my previous post )
The early Ford Model-T used ... 16 ... Permanent Vee-Magnets ( not 24 magnets )
( on the front-side of their  Model-T transmission Flywheel )
Ford's Model-T magneto Flywheel assembly â€"
360* / 16 magnets = 22.5 degrees between magnet poles
Edward Leedskalnin's magneto Flywheel assembly â€"
360* / 24 magnets = 15.0 degrees between magnet poles ( important changes )
Therefore, I must also make the following correction:
re: Ed Leedskalnin customizations / modifications entailed ( at the least ... ) :
Ed Leedskalnin, consciously CHANGED the radius of his Magnetic Current flywheel
from that used by the Model-T Ford flywheel ...
to accomodate the 360* / 24 magnets = 15.0 degrees between magnet poles.
Not to mention his using 5 layers of magnets ...
another correction ... is that about a 7.5 fold increase in magnetic strength?
Now ... looking again at the Code 144 and Coral Castle Code ... Websites ( Beautiful work there! )
and it looks like,
Ed knew exactly what he was up to and knew exactly what he had to design-CHANGE!
p.s.
Gustav Pese
Look at the style of Bell that Ed used. Specifically, look at the Bell clapper.
The Bell clapper ( which 'points' up to its own Bell, naturally ) ...
Is that not the same basic shape as ... 1 of Ed's Magnetic Currents?
( tiny diagram on the cover of Ed's book ... Magnetic Currents ).
Another funny coincidence.
cheers
cosmic-cam
hammuraby
i have a good news on the usefull tech in coral castle,
but no for who think to Ed mith ; looking for something un....
http://www.overunity.com/index.php?topic=6911.0;topicseen
i wait a your answere, especially if you think that the BASE is reach the same work in free energy, (not Over Unity)
quarktoo
Everybody looks for "the big secret" to Ed's motor. Meanwhile, everybody ignores the pink elephant in the room.
Ed. Leedscalnin
Ron Hubbard
Stephan Marinov
What did they all have in common? They all used the same basic principle to produce near perpetual motion through AB effect.
What people don't seem to figure out is how they start the coil. The circuit must go through the inductor in order to separate the charge to initiate the AB effect.
Here is a link to some papers about Marinov's work that teach you how it gets done:
http://www.overunity.com/index.php?topic=10074.msg266890#msg266890
ramset
Sir
Marinov and the AB effect!!
More please!!
quarktoo
Quote:
ATTACHED is a primer to a practical demonstration of AB effect.
You will need to take special note the coil/motor starting procedure. You have to send the coil start/charge  impulse through the core material from one side to the other. This splits the electron stream and traps the spin curl wave in the right place. That is the big secret to Leedskalnin's motor, Hubbards motor and a bunch of other stuff.
If you read the Seattle Intelligencer news paper account of Hubbard displaying his motor on the lake near Seattle, you will note how he had to strike a wire against an iron plate for nearly ten minutes to get the transformer up and running properly. As I recall, one of the attached papers also talks about the difficulty in getting it started in a similar fashion.
Why the tapping ?
What is it really doing {the tapping]
Please !!
Chet
Ps
Thank you for still being here [no self banning in the above thread]
I was quite impressed with your self control!!
You are a teacher [so you've said]
TEACH!!
Stop tossing these beautiful seeds around like Chaff!
Thanks Grandma
quarktoo
Not sure what you mean by tapping. Do you mean striking the wire against the core with the core itself in the circuit during starting?
