Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
alan
does the energy balance (including ionization energy) show an excess of released energy?
or can the ionization of oxygen be 'free' using the VIC method?
is the hydrogen atom really being consumed and gone, like meyer said?
thanks
h20power
Quote from: Outlawstc on March 16, 2009, 08:47:18 AM
h2opower,
from what i have read of your explanations of stan meyer suppied by  ramset on another thred, tell me if im correct, you are sayng that when you are capable of putting oxy in very high energy state that is all you need to seperate hydrogen and oxy(water) ? there is no need for water splitter injector? just the need for thermal heat spark?
outlawstc
In the patent it is stated that spark or heat ingition source will work, but the way the injectors work is by creating micro-mini capacitors that short out as the droplets evaporate, just as long as the relaxation time is greater that the evaporation time. From what I understand both are taking place at the same time some of the water injected will be turned into hydrogen and oxygen and the rest left over will ignite when that hydrogen mixture is set off by either spark or heat ignition in the presence of the unstable oxygen atoms. Hydrogen will flash at 500 degrees C and that will happen in a diesel engine. The unstable oxygen atoms will stabilize by taking the hydrogen atoms from the water molecule of any that did not break up into hydrogen and oxygen for it has well enough energy to do so.
As far as Ramset, I am have not seen his work, and I do belive I am the first to every talk about the Gas Processor and what it is doing. I know I am the first to ever show the math in comparision to the energy content of gasoline, besides Stanley Meyer(though he only stated the end results). I could care less of someones elses work for I have not read it, all I care about is starting the energy revolution, and I gave the technology away for everyone to have. That is the only way any of us will ever see this type of technology, for someone to lay down the bag of greed bricks and do the right thing.
Could you post a copy of his work, with the dates it was posted so I can read it? Thanks
h2opower.
h20power
Quote from: alan on March 16, 2009, 09:36:27 AM
thanks
The hydrogen atom shouldn't be consumed for all that is being created is water vapor, it the lectures Stanley Meyer says the oxygen atom over compensates giving off the high energy yeilds beyond the normal hydrogen/oxygen reaction. The all copper VIC should be used on the Gas Processor, the SS wire VIC is for use of any gap 0.06-0.01 inches and that is only found in the Water Fuel Capacitor. Note there are two types of VIC transformers not just one. I posted a video of the Gas Processor in action on the other site from MIT.
Everyone should take the time to read the whole thread as there is a lot of information given in there, plus note I was learning more as I went along. Trust me I really wont re-write everything that I went over in the thread.
Best wishes,
h2opower.
Dave45
I believe the gas processor is vital to the injector, as per h20's explanation but I would also like to see it applied to the wfc as in a heater or torch.
Maybe separate the h an o at the cell run the O through the GP and recombine at the orifice, this would also make it less likely to flashback.
h20power
Quote from: Dave45 on March 16, 2009, 08:32:59 PM
Say your talking about the gas gun, and yes that would be very interesting to see for as you raise the voltage to the Gas Processor the flame should increase in thermo energy released. So everyone build the Gas Processor best you can, do your homework to make sure you understand what is it's purpose. For remember there are many ways to do this, all that work win the energy independence fight.
Time for real change,
h2opower.
