Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
kolbacict
See what I thought.
If you apply the same voltage of one frequency and one phase to two electrodes.
Edward also mentioned the PLL system here. Then this high frequency should not heat the water.
At the same time, the entire cell will be affected by this RF voltage.And will try to play with the third mass electrode. In various position.
h20power
This is the correct way to wire up the Voltage Intensifier Circuit transformer. Note the polarity of the primary coil as when a pulsing transformer is fed power the polarity reverses on the secondary side, thus when back engineering this technology to make this work correctly the primary is wired in reverse of the secondary to get the correct polarity on the resonant cavity as shown.
Folks need to understand that you can't do this your own way, you can't run around making up the rules as you go along, all you can do is move to understand the science behind this technology as once that is understood you will know what can and can not be changed. As I stated many times this technology is not simple even though it does appear to be simple at first glance as there are so many rules that must be followed to the letter in order to get the technology up and working correctly. You have to learn how to make proper soldering connections for high voltage, fully understand how transformers work, and the list goes on and on, plus you must learn things that aren't yet in the science books.
Right now the only thing preventing me from bringing this technology out right now is I simply do not have the needed machines to move forwards yet. Once I have those machines I can move to put this technology into the marketplace. I feel my days of teaching this technology are over as I must be the change I wish to see in this world and I see no one at this level of understanding to be close enough to bringing this technology out other than myself right now. If I could just get the support of the people things would move along much faster if not then I must keep moving along at my own pace and the world will have to wait. Meanwhile the window to do something to turn the tide on climate change keeps getting smaller.
Peace everyone,
Edward
kolbacict
QuoteFolks need to understand that you can't do this your own way, you can't run around making up the rules as you go along,
What can I do, right now I can't have anything but my own brains. The person who promised me to talk to our bourgeois did not do it today. There is no one to count on, no one to rely on in this country.
Except for himself, of course. :) In your country may have drawbacks,i don't know but everything is knew in comparison. I would love to change. :D
h20power
IancaIV,
Why would you post that on my thread? It's mostly all wrong from people whom just took people's money and ran off with it. Peter Linderman is describing a lightening strike where the dielectric material is overcome resulting in a discharge which brings the voltage potential difference to zero. He has no idea how this technology works right to this very day. I spoke to him about this discrepancy and for the most part he told me not to worry about it. I also ask him why he wasn't going to build this device even if just for himself and he just told me he had no desire to do so because of the cost involved. Yes, I actually spoke with him.
Aaron and I? lets just say I truly no longer wish to go there in talking about what happened between us as it was all bad. Parts of his circuit is okay but back then none of us really understood this technology and at the time I was the only one of us making use of the scientific method. Now after all I have taught anyone that is truly listening to me when you look at Aaron's waveform you know he is pushing current through the water bath as the scope shot tells us he is doing so for there are only positive pulses being sent to the exciter array. This is something you all should have been able to point out for yourselves to me, yes? Well, you would be able to do so if you were actually reading and listening to what it is I have been saying.
Back then we were all new at this and something to note, Aaron's advice to Ravi about putting a coating on the metal stopped Ravi's cell from working. Now I just talked about why that was as putting a coating on the tubes adds in yet another dielectric to the mix and we don't want that.
In that pdf file they even stole some of the things I was doing which turned out to be wrong and never gave me credit for the things I did even if I was wrong at the time as that 45° angle wrapping was done by me as I was trying to learn just what bifilar wrap actually was and the only example I could find at the time was with this tape. And I just so happen to have a witness isn't that right Jerry Volland?
I even spoke with Bob Boyce and we both concluded that what he was doing was something different from what Meyer had done and yes he agreed with me. You see I am not new to this for as I stated I started in on this technology way back in March of 2006. But I knew the scientific method was going the long way around but I also knew that it produced results so I made use of that tool. And again of all those people spoken about in the pdf file I am the last one left standing that is still actively working on this technology.
I've even made friends with Dave Lawton, and I actually spoke with Dr. Dingle before he passed away. You see I would actively reach out to anyone that was working on the technology at the time so that we could hopefully compare notes with one another. I worked with Max Miller and offered to work with Zero Fossil fuels but he declined. I even tried to work with Russ but that turned out to be impossible. No one was willing to make use of the scientific method and a lot of people just would lump in a lot of different unknows to try and explain the things we didn't yet understand about this water for fuel technology. Back then I was very willing to share my information with people but through the school of hard knocks I learned to stop doing that. When I speak of this technology now it's from a perspective most simply do not have as none made use of the scientific method but me back in the day and as I already knew that method does get results, though it does take a long time.
Those were the days when we made a lot of mistakes but I'd push on making use of the scientific method even when most told me that science can't solve this technology thus I should give up trying to make use of that tool on this technology. Back then we didn't even know that we needed to use a differential probe to be able to take readings of the cell in action thus grounding the thing out in our ignorance, lol. Now I finally have the science I was seeking back then and just need the funds to see this through as this technology isn't free. It kinda feels strange being the last man standing still working on this technology but once I started getting the results folks deemed impossible it struck a fire in my efforts to finish what I had started. I can't tell you how many people told me that you can't put high voltage directly to a water bath as that was physically impossible, but oh how they went silent when I actually did just that. It's been more than 15 years since I started on this technology and only now am I ready to put it on the market where it can aid humanity in turning the tide on our climate change problems.
Take care everyone,
Edward
