Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
kolbacict
https://wp.icmm.csic.es/wp-content/uploads/sites/32/2015/06/JPCL2010.pdf
But carbon dioxide is an insulator, and water is a conductor.
It is not difficult to create any electric field in carbon dioxide ... :)
kolbacict
But I came across one interesting publication. :)
Sorry that in Russian, perhaps there is no translation.
Perhaps you have programs that can translate this pdf text automatically.
I don't have one. And my computer is old. Very old. I don't even have unlimited internet.
In this work, people nevertheless create standing waves in the water at resonant frequencies.
Just as it happens in air waveguides and resonators. And even adjust it with a movable piston.
Only the frequencies are very high ...
https://thewire.in/energy/challenges-aplenty-in-indias-pursuit-of-becoming-global-hub-for-green-hydrogen
Coming up on 5,000 acres in Jamnagar, the Dhirubhai Ambani Green Energy Giga Complex will have four giga-factories that will make and integrate critical components of the new energy ecosystem — solar modules, batteries, electrolysers and fuel cells. The group is using acquisitions to gain know-how. In batteries, it picked up Ambri. In solar, it bought Norway's REC Solar Holdings. In hydrogen, it has tied up with Denmark's Stiesdal Fuel Technologies.
Stiesdal has designed an electrolyser that can be produced cheaply — about €200 ($231) per kW, in a market where prices typically range between €500-1,000/kW. It runs on alkaline technology, not AEM, PEM or solid oxide. By not needing rare metals — like iridium or platinum for PEM — company founder Henrik Stiesdal told ReCharge, it can be produced at scale. Not needing high temperatures to operate, it can also be bought by a wider set of customers — which gives another boost to scale.
The US DOE price target : 100 US$/KW electrolyzer production costs
when per Kg hydrogen price 70-80% are electricity price dependent, a save 20 US$/MWh e-generation (green,renewable) gives the way free for the 1 US$/Kg hydrogen production costs !
Happy weekend
OCWL
h20power
Quote from: alan on November 25, 2021, 11:05:14 AM
Hi Edward,I believe you 100%. I'm going to try to collect your posts from this topic and read them.
Is your VIC similarly wound as 6-1 and did you also use custom coated ss wire for the 2 chokes?
btw science is catching up:https://chemistry.anu.edu.au/research/research-stories/triggering-bond-cleavage-electric-fields
https://www.sciencedirect.com/science/article/pii/S0167732221016731
https://arxiv.org/pdf/1611.04677
(haven't looked at it in-depth)
Take care!
Hi Allan,
I posted these four photos of exactly how Meyer built the 6-1 VIC transformer: [size=78%]https://overunity.com/7030/stanley-meyer-explained/msg556858/#msg556858[/size] I did so back in April this year. That is all of the information I have on Meyer's 6-1 VIC transformer as I don't have page 5 of 5, but these goes over all turn count data and more. The formula Meyer made use of is here: [size=78%]https://www.google.com/search?q=wheeler+formula&rlz=1C1ONGR_enUS945US945&tbm=isch&source=iu&ictx=1&fir=Ph6OiBPABOWmsM%252CjZpH0dO5w1HboM%252C_%253BG2H0NJijcgUE8M%252CjZpH0dO5w1HboM%252C_%253BUk1aKHuP406RpM%252CjZpH0dO5w1HboM%252C_&vet=1&usg=AI4_-kSlNN73VMsbenXXKeGVxuGkiLUXpw&sa=X&ved=2ahUKEwiOhMWmhKX0AhWOTjABHbs9AlsQ_h16BAgVEAE#imgrc=Ph6OiBPABOWmsM[/size] As you can see I've done my homework. I normally use heavy build wire or some coatings that have a high dielectric value and most of the time with a rating of 200 degrees C. Thanks to Trump things have become a lot more expensive as some of the wire has to come from China.
I don't use the 430FR wire but another that is a bit more resistive, and the way I build things are a bit different than what Meyer did but it's still a high voltage transformer that is resin sealed to get all the air out and prevent the wires from moving around something I had to learn the hard way having a few of my VIC transformers fail on me, but that's the cost of R&D, huh?
All in all I think I've gotten quite good at designing these transformer bobbins now as I put a lot of thought into each design in an attempt to make them perfectly first time around. All of my problem solving skills come in handy when I design things as I am able to truly think things out and fix problems I had in the past and even go over my designs to make sure I don't introduce a new problem.
I do find it interesting that now they are starting to look at new ways to break the bonds of the water molecules and even CO2 molecules after the the bad talk they give me and others about this technology. But with the water they are still trying to get the hydrogen and oxygen separately when this technology produces them together right in the middle of the capacitor plates. But it just lets me know that when this technology does hit the market they will no longer be able to say, "It breaks the laws of thermodynamics," or, "It breaks the laws of physics." Since I have already solved this technology and even came up with a whole new theory for the science books I guess one day I'll be in one of these papers.
Well, I hope you the best with your designs.
Take care,
Edward Mitchell
h20power
Here are my some of my first prints with the SLA printer. I still much to learn and hopefully have things dialed in soon as thus far with this learning curve I already damaged the FEP and had to order a new one. Once I have everything dialed in and things are perfect it's time to move on to the next step as my aim is clear in attempting to put this technology on the market.
I put all of my trail and error testing into these designs I build today and I really don't think anyone that I know of designs these bobbins the way I do as these are results of the many things I've learned through failure.
This print was doing okay but I had to leave the machine unattended and it ran out of resin :o . It looks like I have to focus on dialing the printer in with the resin I am using so things will be perfect.
A big thanks to all that have donated to the cause of bring this technology to the marketplace as without your support none of this would be possible.
Shalom,
Edward Mitchell
