Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
h20power
Here are the ionization energy levels of oxygen:
• 1st 1313.9 kJ/mol
• 2nd 3388.3 kJ/mol
• 3rd 5300.5 kJ/mol
• 4th 7469.2 kJ/mol
• 5th 10909.5 kJ/mol
• 6th 13326.5 kJ/mol
• 7th 71330.0 kJ/mol
• 8th 84078.0 kJ/mol
Now let us take a look at the reaction to break and form the water molecule under normal conditions.
4 H-O 459 kJ/mol bonds are broken taking 1836 kJ/mol to do so.
2 H-H 436 kJ/mol bonds 872 kJ/mol and 1 O=O bond 498 kJ/mol are formed yielding 1370 kJ/mol.
This is why all scientist say it takes more energy to break the bonds of water than you get from combining them, for the net sum of the reaction is negative, 1370-1836 = -466 kJ/mol.
Now the new reactions after the GP has stripped the electrons off of the oxygen atom are known as ionic reactions. Let’s take a look at the 1st energy level of 1313.9 kJ/mol.
The new reaction to form the water molecule 1st energy level:
2 H-H bonds 872 kJ/mol and 1 O=O bond 1313.9 kJ/mol are formed yielding 2185.9 kJ/mol. The net sum of the reaction is now positive 2185.9-1836 = +349.9 kJ/mol, so now we are getting more energy out than in. To give the energy level a bench mark for comparison the energy content of gasoline is +4864 kJ/mol. So only striping one electron off of the oxygen atom resulted in a positive energy level but still far behind that of gasoline.
Stanley Meyer said he stripped four electrons or more off of the oxygen atom so let us take a look at the reactions as told to us in the patent.
The new reaction to form the water molecule at the 4th energy level is as follows:
2 H-H bonds 872 kJ/mol and 1 O=O bond 7469.2 kJ/mol are formed yielding 8341.2 kJ/mol. The net sum of the reaction now is 8341.2-1836 = +6505.2 kJ/mol
5th
2 H-H bonds 872 kJ/mol and 1 O=O bond 10090.5 kJ/mol = 10962.5 kJ/mol. The net sum of the reaction is 10962.5-1836= +9126.5 kJ/mol.
6th
2 H-H bonds 872 kJ/mol and 1 O=O bond 13326.5 kJ/mol = 14198.5 kJ/mol. The net sum of the reaction is 14198.5-1836= +12362.5 kJ/mol.
Now this is more than 2.54 times the energy content of that of gasoline, and gives a most probable answer to the question of, “How did Stanley Meyer run his 1.6L engine with an hho production rate of only 7L/min.?” For you still have two more electrons to strip off.
What is your take on the math of the process? Am I right or wrong in your view? This assumes the worste case of the reaction, if done any other way will give higher energy yeilds. For what it all comes down to is energy flux density in this case I measured it in joules per mole. @ Outlawstc
Outlawstc
QuoteHere are the ionization energy levels of oxygen:
• 1st 1313.9 kJ/mol
• 2nd 3388.3 kJ/mol
• 3rd 5300.5 kJ/mol
• 4th 7469.2 kJ/mol
5th
6th
i love it.. thank you very much for your insight.
its not the fuzz you gotta worry about in these neck of the woods, its thebuzz
ramset
Well
The two of you are GREAT!!
Thank you for taking the time to share your Knowledge [
Outlawstc
yes when you know how ,you can recognize the science,when you don't,its like another language
The info you two have shared is breaking the language barrier
THANKS
Chet
Thanks Grandma
Outlawstc
QuoteThe new reaction to form the water molecule 1st energy level:
i am gonna make a sugestion of change for words on a specific part.. "more energy then you put in"  thats not tru in a weird sense.. the reason you can separate them at such a high rate is the duality of nature it self.. while +1000 and -1000 may appear to have zero current they are really just trading off light and electrons in resonance (balance).. so it appears to be 0..the duality is it causes the atoms to want to go the other direction of the high voltage.. because opposite attract.
the search for the truth shall bring you one step closer to clarity and one step away from distortion. it will also take you one step closer to intuitive instincts and also take you one step away from ignorance at the same time hey its duality vice versa!!
see my point where this explains overunity thats how voltage performs work its really reflecting another output at the same time. and that reflection of voltage performing work is 180 from what its going lol. its vice versa
h20power
Yes you are right, but I am really talking in the terms in which the science guys can understand it. The energy found here is also the same energy found in a lightining storm, both you and I seem to know that. But the new form of what I like to call, "Tobacco Scientist," keep fighting this information. They fight it will Dr. Faraday electronlysis when it is like comparing apples to oranges. I sat down with a bunch of them and the question I gave to them was, "How does a lightining storm produce electricty?' They couldn't answer that question, and you and I know that is where this technology has it's roots. Mother nature has been showing us the way the whole time, even the way our very own bodies work is part of this technology, for it is mother natures way to make and sustain life. Took me a long time to learn that lesson.
The reason I said it's just changing the atmospher is we do it all the time. Any time you see and engine with a blower or turbo on it, or water/mist/methonal or nitrus oxide you are seeing changes being made to the atmospher to improove the engines performance. It is the same reason why an hho making device added on will also improve performance for blowers also take energy to run them and they do close to the same thing and that is adding in more O2. So anyone that reads this from this point on and says the hho devices do nothing, is siding with the new form of tobacco science guys. For now you know how to compare apples with apples, blowers and hho devices. When comparing them to turbos one can let the cars vacuum perform work on the hho device thus cutting down the amp usage to create the same about of hho gases, carbid tip and myself proved that one. But you will run into a runaway boil off of the water as the temps get higher for lowering the pressure also lowers the boiling point of water.
I'm going to enjoy breaking the chains of energy enslavement,
h2opower.
