Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
Vortex 22
Quote from: h20power on February 19, 2022, 05:26:30 PM
There are a lot of rules one must follow when making high voltage transformers. Here I am vacuum resin sealing the transformer: [size=78%]https://www.youtube.com/watch?v=i0gH4IX5r7g[/size] Now the reason for this is to get all the air out as the air will ionize and that ionization will work towards destroying the wire's protective coating. It also keeps the wires from moving around which will also destroy the wire's protective coating as they rub against each other as the transformer is in operation which is typically heard as a ringing sound. Then you must also choose a coating for the wire(s) that can withstand the voltages you will be subjecting them too.
Most of this I had to learn the hard way as even when I went to the Global Breakthrough Energy conference held in Boulder, Colorado, I put the transformers in some oil that was specifically designed for transformers. The problem with that was as though it did prevent the air from ionizing it did nothing for keeping the wires from rubbing together which again would cause the transformers to fail as once the wire's protective coating rubbed off the current will follow the path of least resistance and the current doesn't much care for going through any resistance wire and will go around if allowed to do so. So, instead of going from point A to point B and then point C on it's way to point Z the current will just go directly to point Z and bypass all the other points if allowed to do so. This you can see when you turn the lights off as you will see the blue glow of arching taking place within the transformer bobbins and you can also hear it.
Now it seems someone has went out of their way to make getting the materials needed to make these transformers a bit costly. Depending on which resistance wire you choose to use the cost of getting that wire is going to be on the high side along with the cost to get practically everything for the Voltage Intensifier Circuit. You see that circuit includes not only the transformer but all the other components as well, like the WFC, Blocking diode, and more. I just found out that the cost of the resin has jumped up to $280.00 per liter if you buy small amounts. Now if you can afford to get large amounts the cost isn't so bad but I'm talking more than $5, 500 to get a whole lot of the resin and its corresponding hardener. Everything from the transformer cores to the wire used has gone up in price and I haven't even started talking about getting the WFC made if you aren't planning on making your own.
I am not trying to discourage anyone from attempting to get this technology up and running but just giving everyone a heads up on what's the actual cost of things so that one can better plan for this endeavor. I did a lot of testing and observed the results of each test as I learned how to do things correctly. The first and second differential probes I got were the wrong voltage rating so I had to get a third with a voltage rating of 15kv. I think with some other parts of the technology I might have to get an even higher voltage rated differential probe than I have. If such an thing is required I have learned to just do it as I will not be able to move forwards if I don't. I have seen a lot of people try and buck the system and saw all of them that did so fail at getting this technology up and running as these rules can't be ignored or gone around they have to be followed and done. Anyone thinking that the laws of physics are just going to personally bend just for you will find out the hard way latter on it just doesn't work that way.
Meyer was a capitalist thus he really didn't want anyone following his work. We all need to be made aware of this as then you will start asking the correct questions when trying to solve this technology and not come in with your head full of Meyer's words some of which have no actual meaning in the real world. You have to do your own research making use of the scientific method as it must be figured out the hard way. I did a lot of this research and shared a great deal of what I found out about this technology to include the actual science this technology is mimicking in nature that allow it to break the bonds of the water molecules outside of Dr. Faraday's electrolysis method. Trust me when I say nothing on earth would be alive if they had to follow Dr. Faraday's electrolysis method to break the bonds of the water molecules.
One thing I have learned is this technology must move into mass production as that's the only way to get the cost of this technology down so that folks around the world can afford to own and have it. This is something Meyer, Dr. Dingle, and a few other also knew. Whomever came up with the idea of blocking and/or never giving their support to anyone who tries to profit from this technology is a true enemy of this technology and wishing things to go on like they are right now forever as that statement is for the current fossil fuel run system to keep on going with no end in sight.
Anyone thinking that this is a easy technology to make and can then be just made by anyone with a set of plans in their hands are just lying to themselves as they leave out all whom are abjectly poor, disabled physically or mentally, the elderly, and the young, plus those that find themselves to be all thumbs when it comes to building anything. I didn't make up the rules of the markets as those things were put in place long before I was born and thus like everyone else I too must follow them.
I feel with all my heart this will be the year this technology finally makes it to the marketplace.
Shabbat Shalom Everyone,
Edward Mitchell
CEO and Owner
True Green Solutions
https://www.gofundme.com/f/energy-independence-for-you-and-me
i pray for your success  be careful
Vortex 22
Hi Edward and All,
Yes I need to learn the basic of this technology
High voltage source VIC
Water fuel cell
Gaz processor ...
Vortex 22
h20power
Hello Everyone,
I had someone ask what it takes for someone to build this technology and did I post enough information for someone to be able to do so? In order for someone to do the same thing I did with this technology they must have some college education and have taken subjects in, Mechanics, Chemistry, Calculus, Physics, Computer Aided drafting, and Strength in materials. I also picked up Architecture, Machine Shop technician, and a whole lot of hand drafting classes, plus the completion of the general college education. This is what it takes to be able to work on this technology and figure out it's secrets. I also took a basic electronics course.
What all this education allowed me to do was to learn how to ask and answer questions using the scientific method and to be able to create something from a dream or thought and bring that something into reality. I design everything I use with the exception of the pulsing circuit. I have redesigned many of Meyer's things to make them more cost effective and to suit the technologies ever changing needs as I learn more about it. I designed the bobbins, the water fuel capacitor, the gas processor, and more and will say one does need a basic education in machine shop to be able to do these things at least it's what I needed to bring dreams into reality.
I never liked the idea of just copying something without knowing how it worked as how would you be able to spot a mistake, error, or misdirection? But I've seen this type of behavior in many that use to work on this technology in the past. Coupled with their arrogance it made for some very interesting conversation as they went about as if they knew it all but in reality didn't have a clue on much of how this technology actually worked. They would just look at the pictures in Meyer technical brief and never really do much if any reading and proclaim they know how the technology works. Just like that one guy whom came into my thread just recently acting as if he knew how it all worked quoting what he had read but having no hands on experience to know that not all of what Meyer said was true and Meyer didn't tell all he knew about the technology as when he spoke he did so in a manor as if the listener knew everything he knew. Folks don't seem to understand that due to capitalism Meyer was very good at hiding things in plain sight for if he had been allowed to just put this technology on the market he would very much be like Elon Musk today. Which reminds me a video just surfaced of someone that worked directly with Meyer for many years and Meyer was able to keep the technology a secret from him as the guy doesn't understand how the technology works: [size=78%]https://www.youtube.com/watch?v=axnb-P4wsDM&t=3900s[/size]. This goes to prove my point that Meyer had no intention of giving this technology away.
As far as Open Source goes that system only works when things have no real cost to them like computer programs, drawings, and things like that for as soon as one needs to buy something then the rules of the Markets kick in and there is no getting around them. This is why I don't believe in Open Source as it leaves out most people on this planet due to the high cost involved in making this technology let alone all of what I just mention above. I can't hand out to everyone a set of plans and tell them to wing themselves off of fossil fuels as it takes money, a college education, and mechanical know how to be able to build and implement this technology into our everyday lives. Those whom firmly believe in Open Source leave out the elderly, the young, the disabled, the poor, all those that don't have any college education, plus those that don't know too much about how engines work as they would need to know how to design things for engines to be able to implement this technology successfully. Can you see how Open Source totally fails at this? I'll give one example of this with someone you all should know Bob Boyce. Bob Boyce put his 25-35 LPM hho producing device on a Toyota Priest. But he didn't know much about how modern day cars actually worked as with modern days cars they are computer driven to help aid with efficiency. Thus adding in a burnable gas will work at first but the computer will resent the fuel ratio use back to 14.7:1 as it was programed to do. So, after about a month the car was getting worse gas millage than it was before he added his hho device to the car. Why? He didn't tell the car's computer what he was doing as the car's computer needed to be reprogramed to accept the new fuel he was putting into the engine. Now if Bob Boyce didn't understand that the car's computer needed to be reprogramed what are the chances of most other people without his education level to know that has to be done on today's modern vehicles be it cars, boats, or planes? You see it's one thing to be able to get this technology up and running and it's a totally different thing to be able implement this technology safely to replace our fossil fuel use.
This is where people like me come in as we have the ability to implement this technology to replace where we use fossil fuels for right now and we understand we must do it safely so that people don't get hurt. This is why this technology needs people like me as we stand out among the rest with a skill set that allows us not to only be able to get the technology up and running correctly but to put it to good use in our everyday lives as we do away with fossil fuel use. This is why I ask for support in making this dream come to a reality as it's going to take the support of the people to be able to get passed all the blocking put in place by the fossil fuel industries, plus all those that sell energy for a living.
Shalom,
Edward Mitchell
CEO and Owner
Vortex 22
Hello,
I have no doubt that Stan Meyer water technology works!!
I pray for your success
God Bless You
Vortex 22
