Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
h20power
Hello Everyone,
When a mistake is made it's vital that you own up to that mistake and then keep it moving and not to wallow or stew in that mistake. I picked a new core that should allow me to build the transformer the way I like and went and designed the bobbins for it already as seen in the photo. Now having learned my lesson I won't move to print this bobbin set until I have the core in my hands and have taken actual hands on measurements of it's dimensions. I also went and ordered the expensive transformer sealing resin so that I can vacuum all the air out of the transformer after it's all wound up. Then and only then will I be able to use this transformer to power up my WFC as those are the rules we all must follow with these types of transformer designs.
The AnyCubic 3D resin printer allows me to do things my way and in such a way that it would be impossible to do by a CNC mill. I put a lot of time, thought, and effort into my designs asking and answering many questions. I'd like to see the designs of others but it would seem everyone has stopped trying to build this technology now. I can say I blame them as the prices on everything has truly went up a lot.
I know that if I had to buy a differential probe and make the WFC now I wouldn't be able to afford it. It shocks me that the resin to seal all the air out cost this much now but it's a must have item so it has to be purchased or the technology will not work.
Well Everyone, this is how it's done mess up, pick up the pieces, and keep it moving.
Shalom,
Edward Mitchell
CEO and Owner
True Green Solutions
https://www.gofundme.com/f/energy-independence-for-you-and-me
h20power
In this post I am going to go over how this technology goes about breaking the bonds of the water molecules scientifically so that there is no doubt if this technology works or not as in no way does it violate the laws of physics as those "paid to say" scientist are running around telling people about this technology.
I will do each paragraph per photo as this will be a graphical representation of this technology breaking the bonds of the water molecules.
In order to understand this technology fully you need to know how to solve work problems in Calculus and Physics. This first photo shows how the waveform should look on the oscilloscope. This waveform has both positive and negative areas under the curve. Since this is a "Work" problem the area under the curve is doing the work of electrolysis and the amplitude of the wave form is doing the work of Ionization.
The second photo shows the area under the curve in colors so that it's easier to visualize what's taking place. When you take the sum of all the energy that which is left over in the red will be all that remains to do the work of electrolysis. This is why what Professor Paul CZYSZ says about the device running for over a half hour and the water temperature hasn't changed is so important as these graphs show why the water isn't heating up and that's because the energy to perform the work of electrolysis got mostly canceled out. You can watch this video to see the Professor describe what he witnessed here: [size=78%]https://www.youtube.com/watch?v=EkjpVcsRQLc&ab_channel=EdwardMitchell[/size]
In this third photo it shows what energy is left over to perform the work of electrolysis after you take the sum. As you can see there really isn't all that much energy left over and it seems to lacks the necessary energy to perform normal electrolysis all that well. When I took actual measurements of the current flowing through the water bath I got a reading of just 0.6mA. So, you can clearly see that after taking the sum there is almost zero work being done in the form of electrolysis.
In the fourth photo it shows voltage performing the work of ionization on the atoms that make up the water molecules in green so that you can easily visualize what's going on. Here the voltage amplitude of the waveform is now over the ionization threshold of the hydrogen and oxygen atoms. As a result the hydrogen and oxygen atoms start to release their electrons and with water if the electrons aren't there to hold the molecules together those molecules simple fall apart and you get hydrogen and oxygen gases plus electricity as those electrons go into the water bath.
The last two photos just show that this technology is mimicking the earth's Global Electric Circuit. And this my friends is how this technology goes about breaking the bonds of the water molecules by way of ionization as it complicatedly mimics the earth's Global Electric Circuit. With this we can switch where we get are hydrogen from away from fossil fuels to just using plain ordinary water.
In trying to get support for this technology I shared this information with folks on twitter as a way to refute the claims that this technology violates the laws of physics by mainstream scientist.
Shalom,
Edward Mitchell
CEO and Owner
h20power
Hello Everyone,
Well, thankfully I waited to print out any new bobbins until I actually took some hands on measurements of the cores as these guys are a tad larger than what was promised, but they will work. I'm almost done drafting up new bobbins for them and will then print some out on the Photon Mono X when finished. Just goes to show I too am learning, lol, for if I had printed some out I'd have had to toss those out too.
Well, that's it everyone. Just a quick update on my progress.
Edward Mitchell
CEO and Owner
nightlife
This in no way violates the law of physics. If anything, it helps confirm the law of physics beyond what is commonly known. Finding and mimicking the most suitable natural frequencies to split H2O into hydrogen and oxygen is just the top of the iceberg. I played with it for awhile years back and it led me to a better alternative. I won't go there but research John Hutchinson's work with frequencies if you haven't already. Nothing is solid and everything is vibrant which can be altered and or even eliminated  using certain frequencies. Keep up the good work it inspires me to get back to work. Thank you 😁
h20power
Quote from: nightlife on March 16, 2022, 02:35:52 AM
Yes, I've heard of Mr. Hutchinson and sometimes even talk to him on FaceBook. One thing to understand about this technology is there is no special frequency as we are dealing with a variable capacitor in that the more gases that are produced the less dialectic material there is between the plates of the capacitor(s) thus the less capacitance it will have which requires a higher frequency to maintain resonance. So, as one raises/lowers the voltage going to the water fuel capacitor changing the amount of gases that it generates it's capacitance changes and the circuit used must be able to keep up with those changes in real time.
With the above graphs I attempted to explain the technology in as simplest of terms that I could to allow people to see just how the technology goes about breaking the bonds of the water molecules differently that normal electrolysis does. Electrolysis is a simple technology and this technology is in every way the opposite of electrolysis as it's a very complex technology.
As for me I had to go back to a very early design to ease the manufacturing process a bit on my end. Now I'm back to using my Tri-Bobbin design from which I started off with many years ago. At this point I am really not expecting anyone to be able to follow my work as I am doing things somewhat differently than Stanley Meyer did as I am just following where the science had lead me. Most people don't seem to understand that Meyer didn't have a finished product as if he did then why was he plaining on building a research facility instead of a manufacturing facility for this technology? Because his life was cut short he wasn't able to fully understand the technology but my life wasn't cut short so I was able to get at the core science behind this technology as a result only because I lived longer. Anyway the Tri-Bobbin design allows me to get around a few problems I ran into when winding these transformers up and now that I can make the bobbins myself actually cut cost a little bit.
I have hope for this year as things are looking good for me concerning this technology, but only time will tell.
Take care everyone Shalom,
Edward Mitchell
CEO and Owner
https://www.gofundme.com/f/77uvw4-energy-independence-for-you-and-me
