Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
h20power
Hello Everyone,
Well when it comes to this technology there seems to be always something new to learn that will stall things out for a bit. I attempted to wind up a VIC transformer but I failed as the wire kept kinking up on me causing it to snap. I ended up tossing out over one transformers worth of wire as each time it snapped it was too short to be of use. But that was not the only problem I ran into. The fins of the bobbin would bend outwards causing the next slot in the bobbin to not take the same turns of wire and this problem gets progressively worse with each slot wound up. As a solution to the second mentioned problem I created some spacers to keep the fins from bending outwards.
As for the 1st problem well that's going to require that a lot more money to be spent as the only way to solve that is to purchase some wire tensioners, lab stands, and the claps that go with them. Due the complexity of this transformer I'll have to get several wire tensioners, and let me tell you those things aren't cheap. The over all cost of all I need cost more than the wire winding machine itself. So, basically I'm stalled for right now until I can get the things I need to keep things going. This truly sucks as I feel I am really close to being able to show a working prototype of this technology and finally be able to get some efficiency numbers on this technology. But I am reserved in my optimism as I have felt that I would have the technology up and running before only to have some new problem come up that needed to be solved as this technology has a way of humbling you bigtime. From what I know about this technology right now things do look like they will work this time around but I know what I know and I don't know what I do not know as this could open the door to a new problem that needs to be solved.
Understanding the science wasn't easy and building it correctly seems to be just as challenging, but I rest on the knowledge that I once got the technology up and running so it's only a matter of time before I get it up and running again. I went back over everything from when I got the technology working and had to make some changes to the WFC. Those changes cost about $550.00 if you include my labor on the materials purchased, tearing down the WFC, passivating the new SS, and putting everything back together again with some upgraded shielded high voltage connection wires. With this technology if you discover that something needs to be done you have to stop and make sure it does get done as there is no moving forwards until the problem is solved.
As I look around I can see that there are less than a hand full of people that are still actively working on this technology now that I am aware of. Most have long since thrown in the towel as how long can one work on a technology and have nothing to show for the time and money put into trying to solve it's many secrets? As far as I know there have only been two people that got this technology to work and I happen to be one of them. The other guy told me he could no longer afford to work on this technology. In total with what was spent on this technology this year I have spent around $90k on this tech since 2006. That alone should give you some idea why no one has yet to show a working prototype of this technology to this date as the cost of R&D to get something up and running are enormous. Once I realized this I simply stopped sharing what I learned about this technology as who out there is willing to spend this kind of money on something that may or may not work? For me I know the technology works but for all of you the video I posted simply didn't have enough information to convince you that the technology was in fact working. I showed no temperature readings, no put input power to gas out put readings, and have even been accused of having hooked up an air pump to the cell and some how managed to get the air pump to put out equally to the three resonant cavities. The other guy I mentioned also didn't take any measurements like this but at least people didn't accuse him of putting an air pump hidden out of sight someplace in his setup.
So, this time around I fully intend on doing things the right way as we all need documentation on this technology since Meyer never allowed anyone to hook up anything to his setups for second source verification. If I do this I will be the first to ever have done so and I am fully aware of this. But for now I am forced to take a break until I can afford to purchase the things I need to keep moving forwards with this technology. Any that would like to pitch in a helping had is more than welcomed to do so as not I really need a bit of help to be able to keep up the pace. The donation link is below my name.
Shalom Everyone,
Edward Mitchell
CEO and Owner
True Green Solutions
https://gofund.me/87a49b22
h20power
Hello Everyone,
I just found this quote:
After hours of discussion between ourselves, we concluded that Stanley Meyer did appear to have discovered an entirely new method for splitting water which showed few of the characteristics of classical electrolysis.
Confirmation that his devise actually do work come from his collection of granted US patents on various parts of the WFC system.
Since they were granted under Section 101 by the Us Patent Office, the hardware involved in the patents have been examined experimentally by the Us Patent office experts and their seconded experts and all the claims have been established.
"The basic WFC was subjected to three years of testing. This raises the granted patents to the level of independent, critical, scientific, and engineering confirmation that the devices actually perform as claimed."
-Stated by Dr. Keith Hindley.
What does everyone think of these words? Note, this is coming from an eye witness to Stanley Meyer's invention as he is one of the people shown in this video: [size=78%]https://www.youtube.com/watch?v=EkjpVcsRQLc&t=545s[/size]
Anyway I thought everyone would like to read what a "Eye Witness," had to say about this technology.
Shalom,
Edward Mitchell
CEO and Owner
h20power
Hello Everyone,
Well, I'm trying to keep this technology alive and posted this video to let people see pure distilled water being broken down into it's component elements, IE, hydrogen and oxygen gas atoms with no added salts, acids, or bases to the water. [size=78%]https://www.youtube.com/watch?v=Bo2ucBWEhLs[/size]
This is just the 8xa circuit  breaking the bonds of pure distilled water. Once I have the last few items I need that will allow me to wind up the VIC transformer I'll hopefully be able to show the WFC up and running correctly. Just know I attempted to wind the bobbin form and the wire kept getting kinked and then snapping  on me. I went through more than one transformers worth of wire and if you have been following this thread you know almost nothing for this technology is cheap. I have to get some wire tensioners to fix the problem and these things are costly. But in the mean time I have the 8xa circuit that I modified and can at least show what science says is impossible.
Hydrogen as a fuel is the right way to go in phasing out the use of fossil fuels. This technology is best suited to the tasked at hand in phasing out the use of fossil fuels, but what I find interesting is most people don't know that vehicles that currently run on fossil fuels are already running on hydrogen as all this technology truly does is switch the source of that hydrogen those vehicles need. To me this is just a sign that the dumbing down of the masses has been successful.
Take care everyone,
Edward Mitchell
Owner
sm0ky2
What are we ACTUALLY talking about here?
Injecting a high frequency/ high voltage A/C current into the water?
sm0ky2
There are recent patents being granted in many areas of this study.
Unfortunately Mr Meyers will have no mention
https://www.sciencedirect.com/science/article/abs/pii/S2451910321000260
