Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 36 Guests are viewing this topic.
carbonc_cc
The good thing about the search for OU is you normally have to accept failure before you start.  That way your not dissapointed in the end.
So.  If those who continue the quest do so, they do it for their own entertainment.
Those who kept their receipts only lost time.
Edited: I'm going to continue with the resources I already have.
chaser
@ nyctuber   you have to make them, just take a piece of 1/4" aluminum plate or what ever thickness you decide on then use a compass or in my case a 9" piece of scrap alloy flat bar drill a 1/4" hole in one end and a hole in roughly the middle of your plate fasten with a nut and bolt then on the other end of the flat bar drill a hole the size of youe favorite felt pen so it fits snug then scribe your circle and cut it out on a band saw. I used a wood band saw with a 11tpi blade and that worked well. If you want the perfect circle and premium edge you will have to take your disk and clean it up on a lathe.
nyctuber
Quote from: chaser on April 03, 2009, 11:28:24 AM
Lol thanks. I don't have access to that type of machinery though.  I have a plexiglass/ industrial velcro setup in mind if i can get off my ass and get it :)
lostcauses10x
Look in your area for a machine shop. Also ask around for a tinker with equipment. I am sure they can be found in your area.
Quote from: nyctuber on April 03, 2009, 11:31:23 AM
queue
Sterling or Mylow please respond:
i am working on my wheel today ..
and have restarted a new rotor array based on your 7 then 6 config . i have 125 rotor mags available to work with.
Our disks are almost exactly the same size.
but i need your help ..
Could you please take the measurements of the space between the magnets in your rotor array and the spaces between the array segments of the rotor.
This would be very helpful to me in trying to replicate your wheel .. i might be able to get mine working today if you can provide the measures
i am asking for..
Sterling: Where did you get the stator you sent to Mylow .. if that is the one he is currently using i would like to order one fedex express.
Thanks
Queue
@ll Thanks for your help and suggestions .. much appreciated.
