Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 74 Guests are viewing this topic.
hartiberlin
Quote from: queue on April 03, 2009, 08:01:15 PM
At the start of each rotor array segment there is a small wall you have to push through to get started.
rotor N meets stator's N = (wall) repulsion.
The question is, what kind of stator are you using ?
If it is pure Iron, this might be different !?
nyctuber
Depending on which way you rotate the rotors :
As the last magnet in each rotor segment moves past the stators S side and out of the stator's field - it get's pushed away by the same amount you had to push to get in to get started moving.
If you flip the stator 180 degrees - the rotors want to go the opposite way ..
Hope i haven't just confused you completely. :-)
Cheers
Q
Mylow's stator is slightly wider than 2 rotors plus the space. Is your setup the same? I suspect that little extra stator width might have alot to do with keeping it going.
queue
Quote from: hartiberlin on April 03, 2009, 07:49:07 PM
@Queue:
Your first magnet stack has only got 6 magnets instead of 7, so just maybe add another one.
Please also show your stator magnet.
Is it also just a magnetized iron U-Shaped block ?
Looking forward to see the video, when all magnets are mounted.
Many thanks.
Stefan . .Mylows latest config is series of seven rotor mags - seperated by 2 1/4 inches, followed at the end by one series of six rotors and then a gap of several inches before starting again ..
i built the six first - instead of last just to see how it would move with the sevens..
i will need to change it to seven and rebuild a final new six with modified spacing or flip my stator the other way ..
In the  video last posted - the stator i used was the one that worked best . .the big grey one on my Mylow page here
http://overunity.ca/Mylow
Cheers
Q
Omnibus
@queue,
That's worrisome. That initial barrier may kill the project. However, I still don't understand how is it that when the N's of the rotor have their first encounter w/ the S of the stator (consider this stator's disposition first) there should be a barrier. My understanding is there shouldn't be. Also (at this same disposition of the stator) the exiting N's of the rotor should be repelled by the trailing N of the stator and there should be no barrier either. Now, if you flip the stator over then it will be unfavorable at both ends.
queue
Quote from: hartiberlin on April 03, 2009, 08:04:30 PM
All my current stators are Alinco ( Aluminum - Nickle - Cobalt ) . .
i asked Sterling this morning to send me specs on Mylows new stator but he has not answered me yet .
i would be happy to purchase one to test with it -  the same stator Mylow is using that is.
Waiting for an answer to my query in this regard from either Mylow or Sterling..
