Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 56 Guests are viewing this topic.
hartiberlin
To ALL,
I did send José (Mylow) 2 emails, after he announced in a comment section
of his last video, that it was a fake.
Here you can see his replies.
Re: Hi Mylow (Jose) , will you finally come clear ?
JOSE
to Stefan:
dear friend you are right wanted to create more research into the
Howard Johnson technology...
----- Original Message ----
To: JOSE <m.....@yahoo.com>
Sent: Saturday, April 4, 2009 6:05:28 PM
Subject: Re: Hi Mylow (Jose) , will you finally come clear ?
Well Jose,
I would suggest to come clear and post with your M....
account at overunity.com
at least some kind of excuse, just say,
you wanted to create more research into the
This would be the best fair thing to do I guess .
Do you agree ?
Regards, Stefan.
JOSE  wrote:
> yes it was intertianing wasnt it so.well its a fake cant talk about it.
> From: Stefan Hartmann <hartiberlin@gmx.de>
> To: m......@yahoo.com; m......@comcast.com
> Sent: Saturday, April 4, 2009 5:53:02 PM
> Subject: Hi Mylow (Jose) , will you finally come clear ?
> Hi Jose ( Mylow ),
> Please read this:
> http://www.overunity.com/index.php?topic=7039.msg168394#msg168394
> Many thanks for the entertaining past weeks
> with your "magnet motor research"
> Regards, Stefan.
spinner
Quote from: wattsup on April 05, 2009, 04:19:13 PM
Regarding the temperature of the magnets, that could simply be explained by the rotors being glued to the aluminum plate which acts as a heat sink or heat exchanger drawing heat from the room and heating somewhat the rotors. The stator is cooler because it is both not on the plate and also it is continuously fanned by the passing rotors.
If you think about the heat transfers in different materials, heat sink can draw/emit heat as long as there's heat difference.
Blowing air at the stator magnet would not make him colder than surroundings..
Cooling of that magnet was simply a .... made by Mr. MyLow.
Cheers!
"Ex nihilo nihil"
lostcauses10x
hartiberlin
What would you expect him to say?
The method he has used will leave the question of was it real, or was it fake for a long time. Hell he may have turned himself into a legend.
hartiberlin
Hi Clanzer and to all builders,
if you try further with your setup,
I would recommend using and playing with iron core pieces on the rotor magnets and on the stator magnets, as in my experience from my old Howard Johnson trials I did 20 years ago,
only something with 90 degrees iron core pieces might work.
Have again a look into this early TOMI setup:
http://www.youtube.com/watch?v=u5mYm5nO5Fw
Okay, this was not the Howard Johnson setup but later,
when we discovered 90 degrees iron core pieces, which
guide the flux asymmetrically away from the sticking points...
Also the right thickness of an iron core has some kind of magnetic
viscosity buffering the flux, so just magnets on magnets alone
will probably never work, if you don´t use pure iron magnets...
Too bad, I never had the time to finish this work and was sidetracked..
Regards, Stefan.
canam101
Is this next? Pinestone, on the steorn forum just said:
Let me clarify my statements for the paranoid trolls:
My bro-in-law makes hydrogen. He's generating it with simple electrolysis. He uses a 12 volt motorcycle battery to power the conversion. His nearest neighbor is about 1/2 mile away. He's not using it to power his home.
He charges his batteries with a dc pulse obtained from a diode/coil pickup mounted near a spinning disk with magnets mounted around its' circumference.
That's all I claim or will say about this topic. I regret saying anything at all.
Although he regrets letting the cat out of the bag, he might change his mind if asked and get the forum connected. Worth attempting?
