Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 50 Guests are viewing this topic.
PaulLowrance
wattsup
@sterlinga
Could you please take a read of my post located here and let me know if you can ask Mylow for a time line and if you need a list of questions.
http://www.overunity.com/index.php?topic=7162.msg170537#msg170537
@all
If you read the above post please keep any non-build related responses in this thread and not put it on the other thread. Thanks for your cooperation.
mscoffman
Someone should try using an electromagnet (some wire wrapped on a nail) as the
stator magnet so that the field strength of the stator can be made low and variable.
My feeling is that the sticky point is a function of both the magnetic coupling strength
and the total wheel mechanical momentum. That is, If the wheel is heavy enough it will
break through the sticky point cause by cogging. Carefully adjusting the field strength
so that the wheel can just break through it may be the key. Whether there is energy
loss vs energy gain around the loop will determine whether the wheel keeps running
or stops in a lower momentum turn.
One of the previous post says a person thought that some of mylow's magnets may contain
batteries and a special pulse circuits. Sending an NSA agent out to retrieve misplaced hardware
might not be so far out of the question. Evidence is that Mylow's wheel is now running shorter.
Other then that this is pure speculation.
This is why I recommended that we stop listening to Mylow; he doesn't seem like he has a full
complement of technical knowlegability. It may be possible for a non-knowlegable person
to come up with some thing new, but it less likely he would be able to have the skills to
evaluate it properly or to make any progress extending it towards a goal. In otherwords it
takes a replicator to make sure something is replicatable.
I disagree with user Higgs_field that this is not worth studying whether it was initially fake or not,
you could have Mib's demonstrating something in a very fake way that is actually true to try to
discredit it. The parts about the stator discharging and the wheel continuing to run are worth
trying to replicate. Efforts take a certain amount of time to mount and should not be stopped
prematurely.
:S:MarkSCoffman
