Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
pinestone
Quoteauthor=queue
The 'edge' (lowest potential) of the field is somewhat spatial and chaotic as it passes through other matter. The magnetic effect is minimal. However, as the susceptibility of matter increases, the flux reaches a higher density, and less passes through.
It induces the matter into order, as their domains align with the field.
This 'toy' uses poor quality magnets and the 'edge' isn't so well defined. Finding the right combination of field interactions to transverse their edges is like hitting the biggest jackpot any lottery could promise.
It's probably not something one could even calculate, even if one knew all the variables.
Remember the video where Mylow held up the iron filings to the rotor mags? It's quite obvious there's a Transverse Wave passing through the filings.
http://en.wikipedia.org/wiki/Transverse_wave
I believe the boyz at Steorn stumbled into the same thing. Crappy magnets-
Did you ever see a wind-generator magnet ?  They're usually flat, curved, 120 degree Ferrite.
Wear out quickly, but easily replaced. Relatively cheap.
The wonder wheel. Take it apart and try to rebuild it.
They tried and failed. Mylow tried and failed.
and here we are.
Anyway, that's my opinion.
nyctuber
Quote from: fleubis on April 13, 2009, 11:35:56 PM
This latest video looks pretty good. Hope everyone caught that Mylow says both  "poles" of the stator magnet are the same. Some replicators seem to have assumed one N and one S, but Mylow says the stator is magnetized thru the thickness. This is what he demonstrated in his hold videos with the compass which many of us passed on as an anomaly.
The original horseshoe magnet stator had been thru-magnetized when he bought it. He remagnetized it crosswise and subsequently (supposedly) got the motor to run.
wings
Quote from: nyctuber on April 14, 2009, 01:12:36 AM
similar to VTA  ???
AnandAadhar
Quote from: libra_spirit on April 13, 2009, 02:35:14 PM
Thanks for the updates,
I set up a 6 - 3/8" diameter 1/8" thick Aluminum disc, I happen to have, and started playing with a horse shoe magnet. What I notice, is at approximately 1" from the edge the Aluminum vibrates up in rings. Slide a finger very lightly along the disc even at the opposite end, and you can sense these rings. I feel this at forehead also. It feels like a pressure outwards from the disc at 1 - 1/2" in all the way around.
The ridge of the vibrating ring is exactly under the blotch wall of the magnet at about 1 - 1/2" inwards from the edge. There is a second ring back towards the center, as I slide the magnet back towards the center, they both flare up again. These are the vibrational resonant diameters of the disc for this magnet. You may be able to see this using a lazar reflecting to a wall at distance if you are not sensitive to torsion fields, I have not tired that one yet.
Vibrations in Aluminum will set up a standing wave, at the nucleus where the weight of the metal is actually located. Magnetic field can alter the alignment of the nuclear isotope chains.
OK now I place a magnet end bar across the horse shoe and the ring flips from a pressure outwards to an inflow vibration. This feels like a sucking inwards on the ring. This shows me the magnet "flowing flux" can in fact flip the vibrational torsion field in the Aluminum to a cold energy state.
Last thing I tried, set magnet at 1 "  back and set the shorting bar on the edge. The vibration field goes Neutral. It stops!
I was most impressed as a sensitive of Torsion fields.
Here is my thinking:
Torsion fields in aluminum and other metals have a very exact linear length, and between vibration nodes the distance is very constant. There are certain distances where vibrations will rise more easilly then others.
These are the natural vibration distances found in nature. The distance across the electron shell, or the distance from earth to moon. These fall into natural fixed distances, and lengths built on octaves of these will vibrate up very strongly. You can multiply them by 12 repeatedly to get  any size you want.
Diameter of a disc to the nearest hundredth of an inch can produce strong vibrational effects without using any magnets.
Now I have a confirmation that adding the magnets blotch wall over the vibrational ring will actually power it up and flip it inwards or outwards. This is hot or cold energy from a sensing standpoint.
I believe I read that Mylows ring is 17.5" in diameter.
Also on the second vedio it appears the magnet is way too far away to be propelling the wheel using magnetic field alone. This would also make sense if it were a vibrational torsion field effect.
All matter is made up of a dual opposing spin system at the atomic level, if you can unbalance the spin suposedly you can create motion. Aluminum has a magnetic hook at the proton level. Magnets can interact with it to create nuclear effects. They manifest first as vibration, and if vibration is set off balance into a rotation then motion is possible.
Because the precession frequency of a magnet is up around 1 Ghz at 1 Tesla this is a tricky balance. The Aluminum precession frequency at the neucleus is down at around 1 Mhz. They precess in opposing directions. The proton shell drags against the electron shell, and this is the wheelwork of nature always present and always stablizing the outer rings of the atom no matter how hard we hit them from outside.
Have been logging a few of these vibrational resonant lengths for some years now.
http://magnetism.fateback.com/Matrix.htm
May have to explore Aluminum atoms next it would seem. There should be a correct diameter that will raise the aluminums natural vibrations. If Myow has acidentally come close we may be able to get much closer by experiment.
We sould be able to measure the exact distance between the rings on the disc to discover this and then cut resonant Aluminum rods to verify it. They should vibrate up in a hand without any magnets present.
Will work on this as I get time.
Dave L
Thank you Dave for pointing this out, especially your page on the OU properties of the flywheel is very interesting to me.  I always thought  the Mylow thing a great flywheel anyhow. But, not just for the Mylow case (with you suggesting that Mylow might work with an off-center flywheel effect), it is also of use for my IPMM research. I've been trying to engage a flywheel and gravity mass to break the equivalence principle of equating gravity mass with inertial mass and thus achieve OU for my rotor setup. And you confirm the correctitude of this search. Thanks a lot!
Aadhar
IPMM pages: http://www.overunity.com/index.php?topic=4449.0
Anand Aadhar free energy research pages: http://theorderoftime.com/science/free_energy/index.html
AnandAadhar
Quote from: capthook on April 14, 2009, 12:20:23 AM
Why, with very limited data , have so many chosen to ignore one of the few we actually DO have?  The video that shows an extended run, with a fixed camera and large viewing angle.. (but NOT showing the start-up - yeesh  ::) )
The graph below is taken from LightRider's video #41 graph.
This section is when Mylow begins talking on the video.  The graph appears to show nothing more than a rundown of a flywheel.
"Oh, the magnets were depleting" :
but it ran for 18 hours @ 140 RPM without slowing down, but not for 4 min.??
"Oh, it was a hoax video to trick us into thinking it wasn't real because the MIB"
but he was too 'simple' to hoax us in the earlier videos, but now he's real good at it?
"There was a lunar eclipse in progress that caused a time-warp/space shift"
oops, I made that one up!
I agree, as I said in my post (page 202) before, that the thing is slowing down as soon as he starts talking. Such depletion as he claims I don't believe in. No way. Its a good flywheel as far as I am concerned....
