Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 51 Guests are viewing this topic.
Rosphere
Quote from: Rosphere on April 18, 2009, 05:39:14 PM
I generally have no faith in permanent magnet motors.  This torque of which I speak is most likely mitigated by the sum total of the approach and departure forces to the stator magnet....
Permanent Magnet Motors always seem to have their sticky spots.
Perhaps the aluminum disc and/or the long, overhead, aluminum-stator-mount-beam Mylow uses 'un-mitigate' the approach and departure 'sticky' forces?
Maybe moving the stator magnet to the OD side, (and twist the plate mag's outward; 180 degrees,) will help reduce sticky spot effects?
Maybe adding additional stators will increase any useful power?
This would be fun to play with, secret I the funds and the time.  I would surly appreciate both!  ;)
nyctuber
Quote from: X00013 on April 18, 2009, 08:26:58 PM
TK is one of four people that have taken the time, effort, and money to replicate Mylows claim, and publish his findings. Straight up.
What are his findings with Mylow's setup? I can't cut through the smarmy megalomania.
X00013
The mind F?CK  is to harness linear magnet E, then engineer it rotational E . The event horizon is endless and apparent. http://www.youtube.com/watch?v=dDsWQiG_YTg
B.Lane
You (clearly) see 1;44 into video a electric moter turning the wheel. What a waste of time.
http://www.youtube.com/watch?v=hYQM8WbCq2Y&feature=channel_page
Bruce_TPU
Quote from: chrisC on April 18, 2009, 04:53:59 PM
Thank you Cat. Apparently TK has confirmed he has replicated myLow's experiment plus a bunch of other improvements according to the replies to the video. I'm excited and hopefully TK can show us what he has done so far.
cheers
chrisC
Hi ChrisC,
Do not be fooled by ANYTHING that TK produces.  He is the same one who hoaxed ALL of us with that self running magnet motor, that Omni, Jdo300 and myself spent all of that time and money replicating.  I figured out long ago he was TK and wrote him a PM and he confirmed his hoax.  Do not trust anything he "replicates" that "works".  It is a lie.
PM LONG AGO from TK in response to me saying he was Al and a hoaxer.
"I think you may have mistaken me for someone else. But in case you haven't, I am really sorry that you lost interest, because there still seems to be active research going on and progress being made. It looks to me like people are learning a lot, I know I certainly am.
When you say "no one got anything to work", that's strange, because I think there are some others who get that silly "AGW" whatever it is, all the time, and it seems to reduce friction and lead to longer rundown times. I'm sorry nobody you know seems to have done this. It's not really that hard, I've done it myself once or twice.
I'm sorry I can't give you any tips, except to have faith in what can be independently proven, and try hard to do the correct control experiments.
(I'm glad you didn't say "wasted time working on...". I don't feel that I am wasting time on Mondrasek's idea, either, even though I know it doesn't stand a chance of working. But if, in a few days, I am the only one who does get one working, well, that would be truly ironic don't you think?
Grin
Cheers all,
Bruce
