Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
wattsup
@queue
If your rotors pull is 1 lb. Your stator should probably not be to high either, maybe 2-3 or maybe 4 lbs. maximum pull. I think this is where most are having the trouble. That and keeping the wheel far away from any other secured metalic objects that the rotor fields could latch onto. There is also the wheel weight of Mylows compared to ours. I wonder how much his wheel weighed.
Also, Mylow already mentioned the new rotors where put in sets of 4, with about 2 inches between sets.
My aluminum disk in ordered so hopefully I will have it very soon. It will have a groove on the edge to have the rotors slide and hold to their positions.
I have a request for all guys with replications.
If your wheel is well populated with rotors and you can secure your stator as per Mylows. Now I don't care if the wheel does not turn on its own. This is not important. But while populated, just give a good manual turn to the wheel and count how long it takes for your wheel to stop on its own. Or if you can, turn the wheel manually until you reach about 140 rpm then let it go and see how long it takes to stop.
Reason for this simple test.
If Mylow is pulling our leg (as many here purport) about magnets losing strength, then his magnets should still be good and his wheel should be exposed to the same drag effect your wheels will be exposed to when turning it by hand and seeing how long it will take to stop.
If your wheels stop within 1 minute or so, then we have a very hard time explaining how Mylows could have turned for so long without stopping at all since additional to that he had to eventually stop it by hand. Others have already examined the video and said there was no cutting or editing of the video. This will clear a good part of any skepticism. lol
miki02131
Removed by moderator. Please keep your insults to yourself.
miki02131
I will be glad to keep mine to myself when Mylow and Sterling recall and stop theirs.
@Stefan, the site owner:
I thought you said that thread should be kept as is and only the other thread should be moderated. Can you please explain to me how my post violate the forum rules? I refuse to believe you would be part of this too.
Miki Out.
plengo
So I guess we are now on the second phase of this saga:
- The secret is out and the creator is hidden.
- Conversations now will be encrypted with ridles and poetry
- Replicators will be blistfully lost in different ideas and tracks but no results and off course many theories to explain the unexplainable
- The creator will be showing an even more obscure video "soon" with outstanding performance but covered with unverifiable facts and free from the charge of having to proof anything (he is hidding from the MIBs now, remember?)
- Some will make some more out of it with books, secrets not exposed, "inner circle" contact with the creator and "very important not disclosed" secrets for a few bucks.
- Still no replicators
- and finally mysterious dissapearance of the creator for good.
As one of our friends here said (with some extra words of mine): if sounds like a duck, walks like a duck, dirty things like a duck, it is probably a duck!
Fausto.
CLaNZeR
Quote from: plengo on April 22, 2009, 04:00:04 PM
Fausto.
History repeating itself  ;D  ;D
http://www.overunity.org.uk
