Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 41 Guests are viewing this topic.
nyctuber
Quote from: fleubis on April 24, 2009, 08:28:58 PM
Mylow didn't say it ran continuously.  If the magnet's flew off then clearly it didn't run continuously.  One partial rotation of powerful magnets could easily dislodge those super-glued magnets. We don't know about this and all these extrapolations aren't very productive. We are probably better served by studying the videos we have and what Mylow actually said.
He said it ran continuously, and that he had to stop it after an hour or so because he got tired from having to hold the base and stator bar in position because it was so 'strong.' Yeah, whatever. Wake me when it's over.
queue
Config 7 * 8 rotors + 1 * 7 rotors ..Spacing is 4 mill ..
Same  stator as Mylow
RPM spin down
http://www.youtube.com/watch?v=AwHVXbpz4cY
Same config top view
http://www.youtube.com/watch?v=YBwYjaCgJJo
Mylow - i know you're probably watching ..
send me the rotor spacing that works for M646 and the HS811n stator and i will replicate
your working motor .. you can PM me here - Youtube - or through Sterling.
Tomorrow i will knock off a rotor from each segment array making the config same as the MYlow last working vid.
Cheers
Queue
pinestone
Quote from: queue on April 24, 2009, 10:33:04 PM
RPM spin down
...Cheers
Queue
Great replication, Queue.
Ahhh yes, the one he couldn't get working after he disassembled it?
Mylows first video clearly shows 8 groups of 6 for all but one group.
The 9th group has an additional rotor magnet.
The spacing between groups of 6 have a gap between each 3.
Isn't that how Mylow's first 'runner' was setup?
You did manage to achieve a long running down-spin with your configuration, anyway.
Can't wait to see your updated version.
AnandAadhar
Quote from: hansvonlieven on April 24, 2009, 03:19:17 PM
I know I am going to get flamed for this but I will say it anyway.
Bearden worked with Howard Jonson for years. He is, I believe, the only one who has publicly stated to have seen Jonhnson's motor running before it was "stolen". Of all the people in the world he had the best start on this technology.
Howard never got a motor going in spite of a monstrous budget and a lot of help. If Bearden knew how to build such a motor, in fact even if he firmly believed that it can be done because he had seen it work, he would not be fucking around with batteries and electromagnets. No-one would.
Hans von Lieven
Hans, Bearden in his book "Energy from the Vacuum" says that he tested Johnson's motor for two whole hours with runs of 15 minutes max. So Bearden himself claims that it existed for real. Would Johnson have deceived Bearden? It never ran more than 15 minutes by his witnessing, and afterwards it was "stolen". Good bearings and a heavy rotor easily give an illusion of the selfrunning status. Fifteen minutes is long but has been done before by the Japan department. May we call Bearden naive here?
Quote page 360
"Technically, Johnson's apparatus asymmetrically and suddenly regauges its exchange forces in such a manner as to momentarily overpower the back mmf region of the engine's rotation, thus producing a net multivalued potential and a net accelerating force around the overall rotation loop. However, correlated distant effects in magnetic materials are known. If distant compensation does occur, then the closed-loop capability might conceivably be defeated, if the total compensation is sufficient to provide an overall condition. Hence the research probably demands attention to maintaining both local asymmetry and distant asymmetry. If the distant correlation effects occur, only in that manner can an overall nonconservative field represented by be maintained around a completely closed magnetic loop. This may be the problem with which Johnson appears to have been struggling for so long. He did solve the problem once, and produced a selfrotating permanent magnet motor that the present author personally tested over a period of about 2 hours. During a two-hour test period, the motor apparatus was allowed to self-rotate for up to 15 minutes at a time. Shortly after it became known that Johnson had successfully produced such a prototype, his laboratory was mysteriously broken into."
Link to the free downloadable book at sribd.com (© attribution, non-commercial):
http://www.scribd.com/doc/13801534/Bearden-Energy-From-the-Vacuum-Concepts-and-Principles-2002-org
AA
Anand Aadhar free energy research pages: http://theorderoftime.com/science/free_energy/index.html
