Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
wattsup
Here's a good small read on the aluminum types.
http://nlites.com/article_aircraft_aluminum.htm
Wondering if you took a positive lead from a car battery and hold it at the plate center and then hit the negative on the rim of the wheel, could this re-align some copper or other atoms in the plate. Nahhhhhh.
nyctuber
lumen
Aircraft aluminum is usually 6061-t6 or 7075. This is a tempered aluminum and is rated 60,000 psi for 6061 and 70,000 psi for the 7075. It's very common, we use it all the time at work.
@Michael
I don't know why you would think the current induced in the plate would equal only pico amps when the field would be as large as the force lines from the magnet on the plate and could be as much as 50% of the total field of each rotor magnet.
This would quick add up as the rotation starts. The large spacing to the stator may actually help the rotor magnets penetrate the plate.
This may also be working on just the edge of this principal and further refinement may yield a huge improvement in operation if someone actually based a design on the process.
That would make the motor operate like an AC induction motor but with the magnetic fields supplied from permanent magnets.
Pirate88179
nyctuber:
Thank you for posting this radio show.  I am still listening to it.  Sterling has now really, really gone too far.  He says things like..."Well we KNOW Mylow's motor worked"......"The NSA showed up and...."  "He has several working motors"
@ Sterling:
Really Sterling?  You know all of this for a FACT?  You saw it run?  Give me a break!!  One of my degrees is from journalism school and the statements you are saying are not justified!  you could say...."Mylow said...." blah blah blah.  "He told me that....."  "According to Mylow...."
This is well beyond ridiculous Sterling.  First, learn a little about science and physics AND the scientific method. Then, learn a little about accurate reporting methods.  I have to do this every day when I write reports on my surveillance activities.  I have to write each report as though it will appear in court and I will be cross-examined on it.  I strongly suggest you do the same.
I will no longer pay ANY attention to ANYTHING you write or ...ah hem, "investigate".  This is nuts!  maybe later, you can get a job as a school crossing guard.
