Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
BEP
Gravity the same as magnetism. Coil overriding the sticky spot.
Jeez.
You can't have two or more sources of gravity here (with any useful effect).  Try 'riding over the sticky spot'.
Does anyone notice the stator wants to be at one particular end of the rotor arrays? Those building will see this. That alone should make you wonder.
BEP
Anybody with an old 'Allied Radio' catalog? The part numbers were the same. Once you have a possible number you can get any recorded specs from the RS website.
I had a connection with them eons ago. The description fits one they used to sell.
pinestone
Quoteauthor=miki02131 ...See it this way, in the same fashion you can't oscilate a point mass along an incline plane using gravity alone, you can never oscilate a point mass under magetic influence alone regardless of configuration.
Miki out.
You can oscillate a point mass using gravity. Pump water UPHILL using gravity and a point mass system. It's called a RAM PUMP:
http://science.howstuffworks.com/question318.htm
It's all in the configuration. ha ha
chrisC
Quote from: BEP on April 30, 2009, 01:40:58 PM
I have seen these RS magnets used in MyLow's latest video in my local RS stores in San Jose, CA a few weeks back. Ithink they were 2 bucks something for two or maybe each but 2 in a package. I will check it out later if I have a chance.
cheers
chrisC
freenrgy2
Fron what Sterling has just informed us of, we know that the rotor magnets are magnetized through their thickness with North being on top. In the video, what polarity of the stator magnets is facing the camera. Are they both N or S or one of each?
I'm wondering if this is a pull-push or push-pull arrangement.
The feel is like what Howard Johnson described with his rail car project. He positioned the car on the track and got it to the spot where the like poles attracted each other then let go...it was then accelerated on the other side by repulsion.
