Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 23 Guests are viewing this topic.
Omnibus
The real problem is whether or not it really does what is claimed in the video -- running for 11, even 27 hours in a self-sustaining mode. No external radio stations, touch lamps or Earth vibrations can nearly supply anything close to the energy required for such run. No way. The nature of the excess energy, if that self-sustaining spinning is real, is non-trivial and is the same as the nature of the discontinuous excess energy whose reality I have already proved beyond a shadow of a doubt. That's "energy from nothing", that is from no previously existing energy source which is only due to a proper construction of the device taking advantage of existing conservative force fields (pre-existing force isn't energy, right?)
PaulLowrance
Quote from: capthook on March 18, 2009, 04:27:20 AM
Watched/listened again....
I hear a 'motor' noise you may be referring to.  However, I also hear a car horn and traffic noises, so it may be vehicle noise?
At 1:32 you hear what sounds like an electric motor powering up.  Or could be a car/motorcycle?
And then he talks....
Again at 2:23 the 'motor noise' and shortly after it starts to spin.
But while its spinning there is no motor noise.
At 2:51 there is a car horn.
Most the video of it spinning there doesn't appear to be 'motor noise'
But the sound at 2:23 IS/COULD BE suspicious?
But the lack of 'motor noise' for most of the video/spinning/start-up could be an indication the other sounds are background sounds?
(Certainly a better video with a larger view the whole time would be of benefit!)
What do you think?
Hi,
The noise is something accelerating a few seconds before he starts the johnson machine. He just made a big mistake, that's all because as you noted, in every case the noise is there just before he starts spinning the johnson machine.
This effect is akin to when a powerful electric motor is started up. It's due to the high current because the electric motor is not producing a back voltage because it's not up to speed. As the electric motor rpm increases, the driving current decreases.
I think the guy will fix this in future videos because anyone legit and perceptive observer will clearly pick up on this video and see it for as it is, and not want to spend time and $ to replicate it, unless only for educational purposes. Just please don't get your hopes up at all!
You have no idea how much I look forward to the day when science evolves to the point where a time camera is possible. Then you people will see what's happening. These people/thugs will go down in history.
PL
Omnibus
That will soon become clear if the guy allows for an independent observation of his claims. If not, too bad. Just placing videos on youtube won't cut the mustard and he'll soon find out how much he's wasting his time (ours too) by simply doing that. By now he should know better. Well, there are always those who still think their tricks are worth it. We'll see. Only time will tell.
Omnibus
Hey, attack duck, don't hijack the thread with your nonsense. It isn't at all obvious that you're the good guy and I'm the bad one, so don't waste your time on that.
Omnibus
QuoteI think the guy will fix this in future videos because anyone legit and perceptive observer will clearly pick up on this video and see it for as it is, and not want to spend time and $ to replicate it, unless only for educational purposes. Just please don't get your hopes up at all!
Why do you think he's doing that, if you're so convinced it's another fake?
