Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
wattsup
@Mylow
Don't worry about anything. Just go and have a good time. You did your bit, it is now up to the world to replicate this and make you proud.
Thanks again and best regards.
wattsup
markdansie
this is a big step forward in Mylow shooting a credable video. Third party validation is still needed .
I might be able to shed some light on why this didnt run for Mylow. His cat appeared towards the end of the video and possibly ate one of the hampsters that were driving it.
Seriously , I am a little more convinced but then ask appart from the value to show it can be done what practicle use could this device be put to given the magnets proberbly do degauss. I am not trying to through a pan of cold water over this...just thinking ahead.
Mark
nyctuber
I believe Queue mentioned that Mylow's platter thickness is slightly less than 1/4", or maybe slightly more. Could be a factor in asymmetry.
Cisco
2 x 18 Low strength bar magnets N pointing to centre with 2 x 1 gap
AZ
AquariuZ,
I believe Sterling reported that the bar magnets are NOT magnetized along their lengths with poles at the ends, but instead through their thickness leaving poles on opposite broad surfaces.
Onward
Cisco
bhaas
Quote from: hansvonlieven on May 03, 2009, 10:49:05 PM
Well done Mylow.
That latest video of yours goes a long way towards establishing credibility. Bear in mind however that complete recognition will only occur when your motor has been properly evaluated by the scientific community and has been independently duplicated.
However one thing causes concern and that is that in spite of your revelations no-one has found the same phenomena you have.
I would therefore suggest that before you allow your motor to be scrutinised you take the motor to one or more locations as far as possible away from your home and see if it works there. This is to exclude the possibility that you are living on top of some sort of magnetic anomality, either natural or man made, that gives you these results.
Good luck with your venture
Hans von Lieven
Agreed.
If you take this somewhere else besides your house, you'll
have peace of mind whether it works or not.
If it doesn't work. Then.......... It's back to the drawing board.
Brad
