Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
AquariuZ
How ever many doubts I have after seeing that last video, I will wait with final judgement until I have tested myself and encourage others to do the same. Easy and relatively cheap to test.
What could make this work is the correct stator arrangement coupled with an aluminum disc of sufficient thickness (at least rotor gap size??) to allow the field to "drag" its heels sufficiently and get the stator past the sticky point.
I hope.
Doug1
 Did a little feel for test using 5 out 6 bars and two dc motor magnets.One of the 6 bar broke when it smashed together but I will get more of the bars today. The only way it could produce movement is if it pushes the bars away with greater force then it is attracted to the bars as a collective group or visa versa. I can only imagine how that would work with the stator offset but it should be easy to measure with a string and a weight to measure the push pull and to see if there is a difference between them.Even a slight difference above what would be needed to stop the wheel when it encounters the stator magnets would be enough to keep the motion going.
  I started pulling a starter motor apart from an old dodge six cylinder to see if it can be modified with this magnetic system to drive it forward later if the weighing of the push pull prove fruitful.
   Personally I dont care about comments other then those that produce results but there is nothing wrong with colorful arguing as long it's equally excepted in both directions. People will always disagree even to the point of being silly. Im sure there were some people who believed light bulbs were black magic once upon a time and the light they gave off was the mind control used by the devil himself. Entertaining as that is still not my problem nor will I except as being mine. You'll waste as much time arguing over sensor ship as you would having to deal with the entertainment of the comments you wish to sensor out. Such is the way the world wobbles. Still not my problem though. I wont be offended if you block me. It will just leave that much more time to do useful work.
  If this design will at best produce a better wind generator to work in lower wind conditions that is enough for it to be worth what ever it takes to make it work even if it is feeble and not able to produce enough output to run anything of use on it's own.
smithandwes
This is real exciting stuff...i will be building my replication as soon as someone else confirms it..and when i do build my working model...i am more then willing to donate money directly to MYLOW :)
LightRider
A remark, here is the acceleration analysis of the last Mylow video and is brother.
The yellow is an area where they adjust the stator height ... this does not seem to change the acceleration curve ...
an explanation? ...Perhaps it had only a minimal effect on the acceleration of the engine...
LightRider
Edit: Add graph in RPM.
powercat
 Will magnet manufacturers rejoice  ???
How long can this keep going without successful replication's
cat
