Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
0 Members and 57 Guests are viewing this topic.
hartiberlin
Somebody asked, if this design could also be used for
a rotational magnet motor:
"videovegetable" <videovegetable@...> wrote:
> Hello all.  For those of us who do not know what a SMOT device is, check out this youtube video.  SMOT = Simple Magnetic Overunity Toy
> http://www.youtube.com/watch?v=u5mYm5nO5Fw
I made this video  long before the SMOT from Greg Watson came out.
I recently found it on an old tape  (Hi8 tape) and uploaded it to my Youtube chanel.
It was done shortly after the guy with the TOMI
design showed his thing publically.
If you would use just an iron cyclinder instead of ceramic magnets roller stack,
it would work much better, cause then I would have no sticky spot at the entrance.
The TOMI with a Roller MAGNET has a sticky spot at the entrance, so you have to
place it into the track from above, where there is no sticky spot about at the center
(If you let it fall into the track for instance)
The table is flat, no incline.
It just accelerates and rolls out of the track with no holding back.
That is got, cause I use at the last stage also these 90 degrees angle iron core pieces.
Just try it yourself. You just only need the right dimensions and thickness for the 90 degrees iron core pieces to guide the flux away and have some magnetic viscosity !
Just with magnets only it does not work !
Best regards, Stefan.
P.S. My voice narration is a bit annoying, yes I know,
I tested it several times and wanted to get the best
shot for the camera and always spoke the same sentence to it.
I should have just posted the scene 2 times only..
but then the video would have been very short...
Quote from: ALFPARTS on May 14, 2009, 09:16:43 PM
913 PM EST -  I am not EXACTLY sure. Let me ask. Things are not always as they appear, meaning that though his set-ups appeared to be different from a physical/visual standpoint they were basically the same circuit.
You've missed your calling. Clearly, with that last statement, you should have been a politician.
So when he uses different magnets, and a different number of them, and the disk turns the opposite direction, and he uses one or two horseshoes or one or two arc magnets as stators, those are "basically the same circuit" even though they "appear different from a physical/visual standpoint?"
I've got to admit, it's hard to argue with that kind of logic.
billmehess
RunningBare
Quote from: billmehess on May 14, 2009, 09:25:42 PM
A work in progress-baby steps.
So let me get this straight, he comes bursting out of no where with a replication he claims works and now hes taking baby steps?, this is FIRE2.0 we're talking about.
After all his contradictions, after giving sterling the run around, after giving another replicator who he said he would show his device too and then backed out with some sad excuse about feeling sad after visiting the grave, some of you still believe this guy, I'm not going to insult any of you, but I mean it when I say it's about time you did a little more thinking and a little less dreaming.
billmehess
Whoa there bucko, I do not claim to have a working motor, I have shown that It does not make a completed revolution. This the 5th video I have posted and I am simply showing another way to appoach the problem by using multiple platforms.
