Howard Johnson Replication Tube Claim
Started by X00013, March 17, 2009, 06:27:33 AM
Yucca
Mylow, please end all this silly conjecture from all of us. Just let someone see the running motor to check it out. or send a runner to someone. I'm pretty sure Howard Johnson would want you to.
Bobbotov
Quote from: Yucca on May 16, 2009, 10:46:51 AM
Can any believer or skeptic tell me why Mylow would refrain from having this whole saga put to rest by the above recommendation? I have my theory but it isn't pretty. I would think that after all of the time that Mylow has been working on this that at the point of finally achieving the Eureka discovery the very first thing I would do is get corroboration by qualified scientists/engineers so that all of this nay-saying could be squelched once and for all and the real business of getting this out to the world could begin if that is the aim. No corroboration is a deal killer and this will never rise above the level of "Mylow says" without it. All of the words on this forum and Youtube and all of the attempts at replication are meaningless if it cannot be substantiated impartially that this discovery is in fact real.
As it stands and probably will stand is this: no one can inspect the device and no one can replicate it. Please tell me how this is going to change the world much less my mind?
wattsup
@Yucca
I though I just did give some insight, but I do not have all the answers, mostly questions.
A one rotor segment disk will have rotors on about 15 degrees of the wheel, all in repulsion mode meaning a south fields is repulsively oriented into the disk. You can say this field covers all the disk to some degree but would exponentially decrease as the field gets to the opposite side of the rotor segments. The stator is passing through all these sectors of the wheel, rotor, just out of rotors, 90 degrees to rotors, 180 degrees or opposite the rotors, 270 degrees, re-enter, compression-expansion, and start over.
At the 180 degree point, I would "assume" the field has less energy, hence less drag, hence less resistance to the stator, hence more speed. But coupled all this with the fact that the wheel wobbles, it will be higher when the 180 degrees is under the stator then when the rotors are under the stator, but again here there is the fact that the rotor could be lifted upwards by the stator making for lots of directional forces trying to keep a rotational mode.
Look, I don't really know but I am open to observe and consider whereas measuring, graphing and saying this shows outer forces is totally irresponsible and unscientific to the nth degree.
wattsup
@LightRider
If you ever had time to burn a cd and send it to me, I could put them all on my FTP site. I am slowly taking time to make an FTP portion for Mylow to concentrate all the builders, photos, videos, etc., in one easy place.
@slipstream
Good work buddy. On your dual stator drawing it would have been good to show the polarities. In fact does anyone know the official stance on the dual stator polarities.
@sterlinga
You probably won't be reading this but just in case, can you please ask Bob Utah to make a build spec on his wheel, ASAP, mainly the base, bearing, axle and disk type, dimensions, etc.
@all
Most forget one thing. For builders and experimenters something that does not work is just as great as something that does. When I do a test that does not work, I don't have to do it again because I learned one way it does not work. But in doing this enough times, we will find ways that do work and ultimately understand the basis.
All this crying, no replication, no replication. You guys are like some bad crew members on Christopher Columbus's trip to the new world, always crying, no land, no land, every day. Geez. I wonder if Columbus yelled a few times, throw man overboard, throw man overboard.
There is no time line here. Things happen, things don't. You can analyze this until the cows fly. It won't mean a thing. Mylow took half a lifetime to perfect this and you guys want it to just flow out of your gouzos. Won't happen.
Then you cry third party, third party. So who will you ALL trust to do such an examination. If the guy says it works, you will find every nick and cranny on the guy to attack his credibility, if he says no it does not, you will accuse him of working for the MIB.
If this was purely a standard off the shelf transformer pulsing thing, wow, would it ever be easy. But in this case we are confronted with the field. Can't see it, can't really measure it without some expensive do dads, can't smell it, can't really say much about it except for a few things.
It's not the device, it's the technique to find its magnetic balance or resonance. Mylow sees or feels this happening. His brother, for all his love for his brother, does not see it. The actions speak louder then words, if applied to what Mylow has generated in both video demos and build videos is more then admirable for someone that had something to HIDE. How f(*kin stupid does someone have to be to not realize this goes beyond all your intello-bricks.
Magnets know best. So if you get to understand field interchanges like Mylow does, no, no, forget the words, the charts, the graphs, just concentrate on the field, you will be able to make his wheel. I think this is what I have learned up till now. Every wheel has a way. Present replications are not working. So what. They could be degrees away from success and then listen to you guys to only give up. Great.
Mylow, has been more then up front. Put yourself in his position. Who the hell would you trust? You know what. It's not an easy question to answer. I guess if it was me, maybe first, I would want to see if someone else can do it. Like he says, to take the heat off him. Why the hell would you say that. IF WE CAN'T AND WE GIVE UP, then the shitsters won. Hourahhhhh.
Actually, the Star Wars analogy was pretty good. Mylow Fieldwalker against Darth Magneto. lol
I would also like to say that the last many pages of grand ferver have been read and found it to resemble a bad jam session where there's a trombone player and a saxophone player fighting it out but both off key. But, to my amazement  a marked shift towards the better verbal manners. Pushes you guys to excel in the pen.
We're all dust in the universe. No place to run. You can only trust the field.
I think we are here to help Mylow explain this to the world without being hammered for every flatulence life throws at you.
So, for a student trying to learn what I would call Magnetic Mylowology, you would need a wheel made in a certain manner with the right magnets AND LOTS OF PATIENCE.
There is common thread to all these Mylow wheels. I think it has to do with the rotor repulsions.
@MYLOW
You should take a break. At least one week of no more videos, or any other talk will do both you some good and also will do the builders some good. This will force them to really play with their wheels very attentively to get the FEEEEEEEEL of the fields. It is not easy when you have this brain that is anticipating wanted results when you should be just experiencing the interactions for what they are.
So here is a question thathas been bugging me for a long time. If the south and north fields exit the magnet and return to the magnet, how does the field know which magnet it came from when there are so many put together? And what would full repulsion mode do to this fields ability to know where to return. Could it be that each magnet has its particular frequency. Like a mother Penguin knows which baby is her's in the midst of thousands of others.  Notice from the rotor gap measurements, none where the same. Does this make x rotors producing different frequencies at different inter-gaps that create some havoc above the wheel. Don't know.
Anyways, as usual, back to work.
lumen
QuoteIn fact does anyone know the official stance on the dual stator polarities.
I mean, checking polarity with a compass is ok as long as you know that the north pointing needle of the compass actually points to the south pole of the magnet.
He should have one of those cool LED polarity testing devices.
